1 members (tesa), 142 guests, and 2 robots.
Topics128,080
Posts1,055,953
Members48,430
#433326 07/17/2008 1:21 AM
Apprentice
Apprentice
Can someone help me please!? I have a 1963 C 10 with a straight six 250 from a 1970 Nova. The tranny is a three on the tree. The casing looks nothing like the images of a Muncie, Saganaw or a Borg Warner. There are only 5 bolts on the side cover. The code on the housing is GM 3743368. The only lead I've had from this code would be a Corvette transmission from the early 60's. There is what appears to be a 1 62 before the numbers listed above. If anyone has any idea what trans. this might be please shed some light. Confused in Carloina.
Do you have a good pic of it? I don't think that it would be a 'Vette trans, they used the same as regular passenger car, either the SM 318/319 (4 bolt cover) or the SM 326/330 (7 bolt cover). I haven't found any 5 bolt cover 3 speeds in my manuals.
Bill Burmeister
In this vendor's catalog there is an exploded view of a 55'-65' 3-speed Saginaw tranny and on p 2 (under 3-speed Saginaw) 3743368 is listed as being made from 58-63.
http://1962-79chevynovaparts.com/catalogPDFs/X2%2002%20transmission.pdf
When you google "gm 3743368" there are other references to this being a Corvette
number.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
Wasn't there a Tremec in those 60's C10's?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
