| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 8 Apprentice | | Apprentice Joined: Dec 2007 Posts: 8 | Can someone help me please!? I have a 1963 C 10 with a straight six 250 from a 1970 Nova. The tranny is a three on the tree. The casing looks nothing like the images of a Muncie, Saganaw or a Borg Warner. There are only 5 bolts on the side cover. The code on the housing is GM 3743368. The only lead I've had from this code would be a Corvette transmission from the early 60's. There is what appears to be a 1 62 before the numbers listed above. If anyone has any idea what trans. this might be please shed some light. Confused in Carloina. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Do you have a good pic of it? I don't think that it would be a 'Vette trans, they used the same as regular passenger car, either the SM 318/319 (4 bolt cover) or the SM 326/330 (7 bolt cover). I haven't found any 5 bolt cover 3 speeds in my manuals.
Bill Burmeister | | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | In this vendor's catalog there is an exploded view of a 55'-65' 3-speed Saginaw tranny and on p 2 (under 3-speed Saginaw) 3743368 is listed as being made from 58-63. http://1962-79chevynovaparts.com/catalogPDFs/X2%2002%20transmission.pdfWhen you google "gm 3743368" there are other references to this being a Corvette number.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Wasn't there a Tremec in those 60's C10's? Scott | | |
