4 members (1955 1 Series, mason86, moparguy, MNSmith), 103 guests, and 1 robot.
Topics128,068
Posts1,055,883
Members48,428
#432053 07/12/2008 10:33 AM
Ok got a question, will the intake and exhaust off a 292 work on a 250? I have found answers going both ways yes and no, witch is it? Thanks Mike
48GMC 5window,350,700R4,p/w,p/b,and a couple of homemade parts!
41 Sedan Delivery next up to be reborn!!
"Nothing is Junk,just unfinished projects" Desert rat with a spray gun!
The manifolds should bolt to the head with no problem. There maybe a difference in the angle that the exhaust pipe bolts to the manifold between the two and three bolt manifolds. The three bolt exhaust manifold also has a larger opening for the exhaust pipe. The 292 carb has a larger throttle bore and would be jetted rich for a 250.
Larry
I don't own a vehicle that isn't old enough to drink.
I was told the 292 was 3" longer but everything I have seen says same so onward with the project!! Thanks for the help.
The differences in blocks between the 250 and 292 is the 292 is about 1 3/4 inches taller, so in some application you could have clearance problem with the hood.
Glad to help.
Larry
The guy that told me this is suppost to be a guru with them but I think father time has kicked in for him. I could not see it being longer just did not make sense.I killed the Idea to put a 350 into the 41 sedan delivery and am going with the 250 and 700r4, hopefuly I can get decent milage out of it.
