1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 39 | Ok got a question, will the intake and exhaust off a 292 work on a 250? I have found answers going both ways yes and no, witch is it? Thanks Mike
48GMC 5window,350,700R4,p/w,p/b,and a couple of homemade parts! 41 Sedan Delivery next up to be reborn!!
"Nothing is Junk,just unfinished projects" Desert rat with a spray gun!
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The manifolds should bolt to the head with no problem. There maybe a difference in the angle that the exhaust pipe bolts to the manifold between the two and three bolt manifolds. The three bolt exhaust manifold also has a larger opening for the exhaust pipe. The 292 carb has a larger throttle bore and would be jetted rich for a 250.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jun 2004 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 39 | I was told the 292 was 3" longer but everything I have seen says same so onward with the project!! Thanks for the help.
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The differences in blocks between the 250 and 292 is the 292 is about 1 3/4 inches taller, so in some application you could have clearance problem with the hood.
Glad to help.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jun 2004 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 39 | The guy that told me this is suppost to be a guru with them but I think father time has kicked in for him. I could not see it being longer just did not make sense.I killed the Idea to put a 350 into the 41 sedan delivery and am going with the 250 and 700r4, hopefuly I can get decent milage out of it.
