2 members (54farmtruck, Rich'sToys), 115 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
Apprentice
Apprentice
I have a 65 C10 that needs restoring. I also am about to replace the engine in my 98 C1500. Please, tell me if this is correct. I think I can rebuild the Vortech 350 that came in my 98 C1500 and replace the DI distributer with an HEI distributer then replace the intake and throttle body with an intake and carb, then add a timing indicator plate. Would that work in my 65 without a computer? Am I not taking something into consideration that may make this more difficult that it sounds?
That should work just fine.
SO MUCH TREASURE, SO LITTLE TIME (and money)!!!
It will work, but you will need the Vortec specific intake manifold to make it work properly, as the ports are different from the older 350s. Carburator intakes with the correct ports are available, Edelbrock has them for sure. Might even have a complete package for the conversion, check with Summit or Jegs for a package like that. You may also need an electric feul pump, IIRC, the Vortec engine doesn't have a provision for a mechanical pump (don't quote me on that, though).
Bill Burmeister
It can be done, I put a Vortech crate in a 76 'Vette. There's a little more to it than just the intake, which is just a conversion intake but specific to the Vortech heads. I think you will also need a waterpump and a flex plate/flywheel to adapt to the older drivetrain parts too, and maybe a new balancer. I would go talk to a GM parts guy, he'll have a list of parts and instuctions as to adapting a Vortech to your truck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I've recently seen several magazine articles about using LS motors in older stuff. You might check the news stands to see if you can find one that is helpful.
I've been thinking about an LSx for an older car, so I've noticed those swaps. But I bet Vortec swaps are covered in detail too.
jdl Offline
You might pm Woogeroo, he has one in his '65(not sure if it is vortech), but he's having problems with the starter so he might not be able to help you right now.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
