8 members (3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, Joe H, Joe Lowe III, 1 invisible), 77 guests, and 2 robots.
Topics128,074
Posts1,055,910
Members48,429
#429548 07/05/2008 3:29 AM
One of my buddies just gave me an early 90's truck seat for my '57. It's REALLY comfy and the bench sits in the cab pretty well. I am confident I can either just drill into the cab and bolt it down or fab up an adapter to use original holes. It is a little wider than the stock bench and as such the indent for one's butt is to the left of the steering wheel. I can remove the cover and disassemble it, using the pieces to make a pattern for a new cover. I have a cheap upholstery sewing machine that I can use to make a new cover. My question to y'all is how hard is it to reshape/pad up the foam such that my derierre is centered over the steering wheel? I have access to a foam and fabric store that sells to the upholstery trade. Thanks, Don from So Cal... http://picasaweb.google.com/orchidskip/2008_07_01?authkey=raifEuGgKvE
it's not really hard it just takes time to re shape the foam. i had to fill some big holes in the foam of my '73 C20 and i think i did it in layers and glued one in and then cut one so the edges facing down were tapered and kept on doing that until it was the shape i wanted it, but i also had my mom and dad help (who own a upholstery business)
Heres how I did the seats for my COE.
I marked out my pattern to cut with a sharpie. Then I used a large flexible grinder pad to do the cutting. You'll definately want to go slow and practice on a scrap piece first. If you have some way to screw the foam down, do it. I used a couple of nails to a piece of plywood.
The way to get a nice smooth edge is to repeatedly bump the grinder on/off. That way you dont get the grinder going to fast or youll send the foam flying, burn it, or cut a great big gouge in it. If you just need to make a cut, be very slow and steady and use the disc to cut along a line like you would with a saw cutting wood. It takes a little practice.
I also used a nice heavy duty piece of carpet pad on top of the foam, as it will hold up longer then just the pad itself.
Hope that helps. Good luck, Jeff
My 1953 Chevrolet
1947.1 Gallery
Moderated by  ndkid275, Phak1
