| | | Forums66 Topics128,052 Posts1,055,717 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | I now have the pushrod and clevis where it can be adjusted (it was corroded) for my new m/c. I have the idea you want to adjust the pushrod so that when the brake pedal is sitting at is resting position in the truck the pushrod is just barely pulling back against the m/c. Correct?
Any tips or advice on adjustment would be greatly appreciated. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | In correct. You want just a tiny bit of free play from the resting place till it starts pushing the master cyl. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Is the pedal just free floating (moving) or is there a return spring? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Big Tee,
There should be a hefty return spring for just the pedal. The master cylinder piston has its own small spring to shove it back but it's not intended to affect the big heavy pedal.
Stuart | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Thanks all, I will look at it tonite hopefully! | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | there is a small hole in the side of the brake lever under the fire wall and a metal piece sticking out from the frame rail to hook it to. mine fell off after the rebuild, not good the brakes locked and you have to bring the pedal back up with your foot. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
