10 members (Donf, Gdads51, Woogeroo, Jon G, DennisM, JoeDude, rfs56trk, Jaison, frogfarmer, Hotrod Lincoln),
164
Mod | | | Forums66 Topics128,035 Posts1,055,528 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 15 Apprentice | | Apprentice Joined: Apr 2005 Posts: 15 | I have a 1939 chev pickup and have the lower windshield frame area that has rusted pits and some holes rusted out. How is the best way to repair this? I had a friend that has body work years ago come by today and looked at my mess. We discussed the easy way of using fiberglass, however I would like to use a more permanent repair. We think that a person could replace the metal with a lot of work.It is not a straight line area. I am sure that this is possible to repair, except that I am new to sheet metal repairs.So far I have been lucky that all my other repairs have been on easy flat panels. I know that this is long winded. Thanks for the help. Ed | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | One of these days someone is going to make a patch panel for this but until then your only option is to fabricate what you need. It shouldn't be too difficult if you have the correct gauge sheetmetal, a sheetmetal brake and a set of shrinking/stretching dies. It'll be a bit of a project but with I doubt anything else, like fiberglass, will hold up to the installation of the windshield gasket and all.
So, hurry up and get that done because no sooner you're finished than someone will start selling those patch panels and I'll buy one... I'm in the same boat as you. | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | If it's structuraly ok but has pinholes I'd be ok with fiberglass. Of course new steel is always the ultimate. I have some pinholes in that area on my 55 and will use glass. My concern is distorting that area trying to weld patches and not having the glass and seal fit properly afterwards. I've welded new metal on all other places on the truck. I'll also use the fibergalss(ground glass and resin)over all welded patches to waterproof the patch. There are always pinholes and you can do more damage trying weld every last pinhole than it's worth.
Good luck,
Keith | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Sounds like a good plan to me. | | | | | Joined: Apr 2005 Posts: 15 Apprentice | | Apprentice Joined: Apr 2005 Posts: 15 | Thanks for the help. Looks like it is time to go to sheet metal class. If I hear of someone making these I will pass it on.
Thanks again Ed | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Would JBWeld not be better than fiberglass in this situation...if you did repair it? | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Or maybe melt lead into the area to fill the small holes??..just tossin here. | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | interesting!
What's JB weld?
Actually I have filled pinholes with lead. I personally like that solution in general.However melting lead against gravity sucks big time. Also some have expressed concerns that if you don't clean the lead properly afterwards you might get some type of lifting later on..after painting..personally I think that's something that can be handled thou.
Just my $.02
Keith | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I had the same issue with my '40. Was rusted at the centre post and outside corners to the point I couldn't open the crank out windshield. Once I got it out of the truck, it was pretty bad. The splice bar that holds the two sections together was even rusted. The cross-section of the window frame is pretty complex to duplicate in a sheet metal shop - curves in ( 2 ) directions and has the groove in it for the glass / gasket. After looking o E Bay for a couple of months, I finally bit the bullet and purchased a new frame from Carter, and new rubber from Steeles. Reused existing glass. All fit OK. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Eastwood has new lead-free body solder kits, its basically ingots of the new no-lead electrical solder adapted for auto body use, and they offer flux for use with it. It would be good if you were concerned about the health effects of lead, and its still metal. You can grind and sand it safely with just a respirator.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | I just found the link to the Eastwood lead free body solder. It's right here should anyone else be interested. Don -- still puttering My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | actually the lead free plumbing solder at yer hardware store works fine for fixing pinholes using a soldering iron  Bill | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | actually the lead free plumbing solder at yer hardware store works fine for fixing pinholes using a soldering iron  Bill Well that can't be right as it makes perfect sense!  Thanks, My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Apr 2005 Posts: 15 Apprentice | | Apprentice Joined: Apr 2005 Posts: 15 | Boy that is a lot of very good info that I hadn't thought of. I will dig into that idea of tracking down some new things to play with. My little bride will be impressed that there is more ways to invest her money.
Thanks again for the great ideas Ed | | |
