1 members (Otto Skorzeny),
115
0
Mod | | | Forums66 Topics128,049 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 28 Apprentice | | Apprentice Joined: Jun 2008 Posts: 28 | Hi, I'm new to the Stovebolt forums but I just bought a 55' 6400 flat bed stake. It was used on a local farm until the owner passed away in 1989, his wife kept it in the barn. Now it's going to haul pallets of sheetmetal for my stainless business in Portland, Oregon. I have to get it running and fix the brakes first. I believe it has a 261, a Muncie 4 speed, and a 2 speed rear end. Check out some pics: http://s311.photobucket.com/albums/kk474/seangardner38/?albumview=slideshowThere are no keys, so I pulled the ignition lock and am trying to find a new assembly, or lock core with keys. Maybe I could just go get keys made to fit the one I have. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | That is a really nice looking truck have fun with it | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Very cool!  Keep us informed on your progress and feel free to ask away. Some of your questions may already have been answered, so the search feature can help out a lot. Good luck with getting her up and drivable. Youll find lots of help here  and even more opinions.  Welcome to the 'bolt'! Jeff | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | There are no keys, so I pulled the ignition lock and am trying to find a new assembly, or lock core with keys. Maybe I could just go get keys made to fit the one I have. Take the lock down to your local locksmith and have keys made for the truck, I believe that the glove box is a different key. The ignition and door locks are the same. I keyed all of my locks the same. You can take the set of locks down and have a new code setup too. I love barn finds! I like the Barn too  | | | | | Joined: May 2008 Posts: 114 Shop Shark | | Shop Shark Joined: May 2008 Posts: 114 | Sharp truck!! The 6400 Chev. trucks are quite easy to work on and parts are readily available from NAPA and CARQUEST auto stores. Its a good size to license and use. I've enjoyed mine a lot! Your's looks pretty solid from the photos. The only problem I've seen with them is that so many are rust buckets, common with many Chevys thru the 50's and 60's. Keep it sheltered as much as possible, also keep the front wheel wells washed out all around. Good luck with your truck!! JAMES | | | | | Joined: May 2007 Posts: 16 New Guy | | New Guy Joined: May 2007 Posts: 16 | on my 64 C60 the drivers door handle lock had the key code on it.my be the same for yours to? | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I dunno what's happening.... I just get a black screen. Maybe because it's after midnight! (: P) A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | You have to let it load, unless the bar at the bottom of your screen says "done". | | |
