6 members (Hanks custodian, Stovebolt48, gswbbc, cmayna, Maybellene, Tronman), 146 guests, and 3 robots.
Topics128,042
Posts1,055,520
Members48,424
#428328 07/01/2008 3:55 AM
does anybody know the part # of the output shaft seal on a bottom mounted PTO for a fuller transmission? my seal is leaking and the shaft slid forward and ground all of the numbers off.
47chevy6400 #428334 07/01/2008 4:25 AM
3B Offline
Hy 47chevy6400, could you give us any I.D. numbers from the trans. or the p.t.o.
3B #428337 07/01/2008 4:54 AM
The PTO manufacturer would be best to know such as chelsea, muncie. Almost any dealer that sells truck drive train could help. I use Drive Shafts Unlimited in San Antonio for such things like this. Even though SA is quite a distance. Postage wouldn't be much. However, take a close look at the shaft. If it is anything less than perfect, it won't hold a seal. Sometimes it's just cheaper to buy another PTO.
crenwelge #428350 07/01/2008 6:13 AM
If you inspect the seal you should find some numbers on the seal its self something like CR-1424 if you take this number to a bearing house they should be able to find you a replacement. Take the seal with you this should also help so if the numbers don't match there books they should be able to match it by its OD, ID, and width.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
HevyHauler #428463 07/01/2008 6:38 PM
i didn't want to drain all of the oil out until i had to because i usually have to go out in the middle of the night to help someone but i ended up doing it anyways so I'll take the seal into town today.
47chevy6400 #428470 07/01/2008 6:45 PM
46Chevy.... In BC it's DANCO Equipment in Surrey. 604-888-0513.
They are the Parker(Chelsea) PTO reps in western CN and have access to Muncie as well.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
