0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | does anybody know the part # of the output shaft seal on a bottom mounted PTO for a fuller transmission? my seal is leaking and the shaft slid forward and ground all of the numbers off. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 47chevy6400, could you give us any I.D. numbers from the trans. or the p.t.o. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The PTO manufacturer would be best to know such as chelsea, muncie. Almost any dealer that sells truck drive train could help. I use Drive Shafts Unlimited in San Antonio for such things like this. Even though SA is quite a distance. Postage wouldn't be much. However, take a close look at the shaft. If it is anything less than perfect, it won't hold a seal. Sometimes it's just cheaper to buy another PTO. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | If you inspect the seal you should find some numbers on the seal its self something like CR-1424 if you take this number to a bearing house they should be able to find you a replacement. Take the seal with you this should also help so if the numbers don't match there books they should be able to match it by its OD, ID, and width. | | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | i didn't want to drain all of the oil out until i had to because i usually have to go out in the middle of the night to help someone but i ended up doing it anyways so I'll take the seal into town today. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | 46Chevy.... In BC it's DANCO Equipment in Surrey. 604-888-0513. They are the Parker(Chelsea) PTO reps in western CN and have access to Muncie as well. | | |
