0 members (), 129 guests, and 1 robot.
Topics128,115
Posts1,056,292
Members48,439
#426044 06/23/2008 11:08 PM
Im finally getting the rear hubs all put back together on the COE and I started looking at flaring the brake lines between the wheel cylinders. Mind you, this setup has two wheel cylinders per side and has a 10" line that goes between them.
But instead of a standard 1/4" inverted flare nut which has 7/16-24 tpi, this has a 7/16-20 tpi, just like the banjo bolts. Where in the heck can I get new flare nuts that have this thread???
Thanks, Jeff
My 1953 Chevrolet
1947.1 Gallery
try 3B
GMC: Get More Cash...
1958 GMC
My Webshots photos
The steel lines would have double flares. The nuts for double flaring might have different threads as well as a different angle. I've always used steel nuts for double flares on brake lines, and haven't compared single-flare hardware with double-flare types. I'm sure someone else can fill in some details on this.
Harvester
They are double flares.
My 1953 Chevrolet
1947.1 Gallery
I may have found a good replacement thanks to Tim at Fedhill Brakes He said the british flare fitting for 1/4" lines has the 7/16-20 pattern but he wasnt sure that it would thread deep enough to seat properly, or that the unthreaded portion at the tip would interfere.
Thanks to Tims info, I think Ive found them locally and Ill know for sure come wednesday when my daily adventures take me by their shop. So until then Im still open to any ideas, and Ill make sure to post whether or not they work.
Thanks, Jeff
My 1953 Chevrolet
1947.1 Gallery
When I first read the title of your thread, I thought you needed a referral to a good clinic!!! grin eek grin
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
I had the same problem on my 64 C60. The line was rusted to the nuts and broke when loosened. I soaked the nuts in liquid wrench, stuck them in a vise drove out the broken line with a brass rod. Then put the nuts on a new piece of brake line double flared and bent it to shape. Not the easiest job but it worked great
I stopped in at the hydraulic shop that usually carries everything you cant find elsewhere. They were able to scrounge up a few 1/4" flare nuts with the 7/16-20 tpi. Its a good thing I asked about the unthreaded end portion as several had no taper at all which had the owner scratching his head.
Now that Im home, Ive slipped them on a flared tube and they look like they will work out great. Its gonna be tight on room though as they are about 1/4" longer then the originals. Ill get some pics when Im all done.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Big Bolt Forum Co-moderator
Rusted nuts, check out the page below, I am wondering if those adapters are for using with the 7/16- 24 nuts.
http://www.fmsiinc.com/brake-line-fittings.htm
1948 Chevy 2-Ton
ok on my 38 1.5 am i going to need these 7/16-20 flare nuts instead of standard. when I did it before i screwed them in but some didn't fit very well. will these be needed at all conections or just at the rear.
Im not sure how the braking system is on a 38...
These tube nuts only go between two wheel cylinders on each side of the truck, only on later models. Typically the brake lines connect to a brass block that has a hole through it where a banjo bolt (hollow bolt) slides through and connects to the wheel cylinder. There are also copper washers that are on either side of the brass block and give a crush seal to the banjo bolt and wheel cylinder.
Does that sound right???
Jeff
My 1953 Chevrolet
1947.1 Gallery
Thanks the 38 only has one wheel cylinder per wheel on the rear it does have the banjo bolts,brass blocks and crush washers. I got away with half way doing things before and am trying to get things back together a bit more safely this time. I didn't have any lines leaking back then but some didn't thread in very far and seeing your post it caught my attention.
