8 members (J Lucas, klhansen, Tronman, electors, 78buckshot, cmayna, JW51, 1 invisible),
73
Mod | | | Forums66 Topics128,042 Posts1,055,497 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | In the latest Hemmings Classic Cars the builder of a Hudson says he put the wheel balancing weights on the inside of the rim to protect the paint. My tire installer says they won't work on just the inside and sometimes has put them on both sides. Is this a fact or is there something missing here? | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Thats how they did my nice chrome wheels on my toyota, they put them inside and behind the spokes so you wouldnt see them. The regular rims they just use the clip on type on the outside. I see no reason why you would need to have it so fine tuned that moving it an inch or two side to side is really going to make to much difference.
Then again, I could be wrong. Just ask my wife. | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | If the balance weight is small, there won't be any noticable effect if the weight is inside or outside. A problem arises with dynamic balance if a large weight is required at one location on the wheel, and the weight is not split approximately half on each side of the wheel. I think splitting weight inside and outside becomes a concern at about 3 ounces at one location on the wheel. And some of that concern is affected by wheel width and wheel speed. A narrow wheel rotating at low speed would not have as much a problem with side-to-side unbalance (dynamic balance/unbalance) as would a wide wheel rotating at high speed. Wheel camber would also be involved, but only slightly with usual camber settings. So I guess the short version of this is that for an ounce or two, I don't think you will have any trouble attaching the weight only to the inside of the wheel.
Harvester | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Wheels can be balanced with the weights on the inside (be it using clip on weights or stickys), however, balncing them that way is not as acurate as a true dynamic balance. Many time, balancing with the weights all on the inside can requre much more weight than balancing on both sides. There's also issues if the tech doing the balncing doesn't know how to compensate for puting the weights on one side, especially when using the clip ons on the inner lip. If your conserned about amount of weight and also want them balanced statically, find a shop that uses a Road Force balancer, they're the most accurate available and will reduce inaccuracy and exessive amounts of weights on the wheels.
Bill Burmeister | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | All of our bulk trucks and trailers have aluminium wheels. We used to stick weight to them. We now use some glass beads that go inside the tire. It's the best balancing I have had in the 44 years I have owned 18 wheelers. They say it can be put in pickup tires too, but I've never tried it. I don't drive my old GMC's fast enough to need balancing and I usually trade pickups I use before the original tires are slick to stay in warranty. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I read that article too and I picked up on that statement. I don't see how it is possible to do the dynamic portion of the balance with weights on one side. I think that maybe there is some sort of compromise which was acceptable to the owner. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | . We now use some glass beads that go inside the tire. It's the best balancing I have had in the 44 years I have owned 18 wheelers. They say it can be put in pickup tires too, but I've never tried it. Sure would like more information on the glass beads. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | They are called Counter Act. We get them from the REMA dealer in Houston, TX. 1 800 343 3661 | | | | | Joined: Jul 2000 Posts: 579 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 579 | Here ya go, Gazim. I haven't used this solution myself yet, but it's on my list of future updates. http://www.innovativebalancing.com/ | | | | | Joined: Jan 2007 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 66 |
Jon
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I've heard of a similar product, but under a different name (don't remember it right off). It's not very effective in light truck tires as it is on larger truck tires. I have a freind that tried it on his lifted Z-71 w/ 36" Swampers, it worked ok at highway speeds (65+) but not very well at lower speeds. Ended up taking the stuff out and doing a traditional balance, no vibration troubles since.
