6 members (tclederman, gswbbc, TIM ZINDLER, HandyAndy, Stovebolt48, rfs56trk), 94 guests, and 2 robots.
Topics128,040
Posts1,055,478
Members48,424
#426265 06/24/2008 3:47 PM
JC
Offline
Hi All,
Any input on leaving my 292 block bare? I just got it back from the machine shop and they shotpeened it. It looks really good, so I am thinking of leaving it as it. Also, what about the head? Is there a reason it be painted? I recall the Santucci book said to use cheap paint if you paint it. Not sure why. I have a Mercruiser 165 250 6 cylinder also and it is glossy black and looks pretty cool.
JC in KC
"The future will be better tomorrow." Dan Quayle
1965 Chevy C10 Long Fleetside
Get a little bit of it wet and see how long it takes to rust! You can also get cast iron color paint. Joe
There is a paint rod shops use on engines that will hold their color. The only exception is around the exhaust manifolds. I don't know what it is called however.
~Jim
You could use gun blueing, that would look neat.
Paint & Body Shop moderator
Go crazy, its only money. Powder coat it!
My 1953 Chevrolet
1947.1 Gallery
Try some high temp clear coating. It's available at most parts stores.
Robert C.
I'm a Genius in the making.
1950 3600
Don't paint it white. Did that once. Regretted it almost immediately.
195? Chevy 3800 dump truck
1973 Chevy C30 cab and chassis
1987 Suburban 3/4 ton 6.2L Diesel
