5 members (Randy Baumann, TexasJim50, 52Carl, dt235sd, 1955 1 Series), 77 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#426113 06/24/2008 2:05 AM
Ok here is the problem. As with most old trucks the original bushings in the steering components are all but gone. When I get up to cruising speed the steering gets loose and when its at a crawl it is right. I have checked all the components and even though the bushings are gone there is no play in the steering direction (side to side and front to back). I have tightened the worn gear on the steering box correctly with the wheels off the ground and also checked the hub bearings. I am leaning torwards worn-out king pins-am I looking in the right direction? Also if they are bad what am I looking for?
I would jack up the wheels and while up in the air catch the tire on the TOP and BOTTOM and try to pull/push on it to see if it wiggles in/out. Get fairly aggressive with it to see if it moves.
While you have it "off the ground" you can also double check other things by catching the wheel on the Front and Back and see if you can move it back and forth. If so double check all the connections on the tie rod and drag link.
If you have a sway bar attached to the front axle then you may want to also check the bushings in it even though I don't think it would cause what you are describing.
Try the test above and let us know what you find. Anyone else have any idea??
bolted54,
I'm not 100% sure I know what you are trying to describe, but I think checking and setting your toe-in might give you a little relief.
This will tend to stabilize any wander plus can help 'load' worn steering components so they appear to have less free play.
There is no substitute for nice new steering components and fits, but 3/16" or so of toe-in could help your current condition.
Stuart
I have done that and it does have a little play when I "shake the tire"
atomarc #426152 06/24/2008 3:58 AM
How would I go about adjusting the toe-in? I understand what toe& camber is but not sure How to adjust what you are talking about
Why not start by replacing the bushings that you already know are worn out?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
jmoore #426192 06/24/2008 7:51 AM
I agree with jmoore, if ya have worn componets they need addresed before ya proceede, get all the the linkage tight an then a fresh alighnment will be in order, that should fix this problem.
Tim
1952 Chevy Shortbed
Photos in Photobucket
