1 members (baldeagle),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 58 'Bolter | | 'Bolter Joined: May 2004 Posts: 58 | During the restoration on my one ton, I've found the original rivets GM used, but I haven't found what kind of tool GM used to set the rivets, does anyone out there have any idea of the tool GM used and where I can find one? Thanks in advance.....Clint | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have installed dozens of frame rivets in sizes up to 3/8" diameter. This thread explains how I do it with the tools I have available. https://www.stovebolt.com/ubbthread...g&topic=0&Search=true#Post380215There is a chance that the original ones are set cold with a huge press or cold riveting machine (anyone know for sure?). Unless you have one of those, and can take your frame to it, installing them hot is the way to go. Check the link above. Grigg | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Grigg knows what he's talking about... good advice.
I would speculate that they were "squeezed" rather than driven at the factory. It would be faster, the results would be consistent, they could be set without heat, it would only require one worker and the noise level driving rivets with a gun would be insane.
During my years in the aircraft industry I've driven more rivets than I can remember but never anything like a 3/8-inch steel one. I'd plan on practicing a lot, they are not going to go down without a fight.
Unless you are intending a "restoration" I'd recommend just using bolts... that's essentially all a rivet is anyway. | | | | | Joined: Feb 2000 Posts: 5,190 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,190 | Watch this if you have a fast connection. Its part of a 1937 film from Chevrolet. You can see how they rivit the frames together. Watch the other parts too, its really cool. Joe http://www.archive.org/details/MasterHa1936_4 | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Thanks Joe, That's really neat. And as I suspected, the rivets are set cold with substantial riveting machines. I priced a modern machine (new) to set cold 3/8" steel rivets, over $20,000 and takes up about as much shop space as my milling machine... Grigg | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | That is too cool. Still a lot of hand work used in those days.
Drew
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Kinda neat watching that old video. Similar to how it's still done in aircraft. The larger rivets, and when possible small rivets, are installed using a devise similar to shown in the video. There are a huge number of smaller rivets that are hand driven with a gun & bucking bar and yes Czechman the noise is insane. Hearing protection is required.  With the advent of fibertow composite body sections the riveting days in aircraft are numbered.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Has anyone else experienced rivets that are stretched or pulled on the top of the transmission cross-member. On my 1950 3600 the very top rivet set on both sides were either stretched or the bracket cracked. Frame flex in that area? | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | I'm not sure that frame rivets were cold rivets. They sure look like hot rivets. I am in the trucking business and we repair and rebuild our own trailers. We use aluminum rivets, but I have set 3/8 hot rivets with our riveter. It is like an air chisel with a .498 shank size. We also use Huck bolts. This is a little more expensive. A puller costs around $3000. There are also some ribbed shank siderail to crossmember bolts that are available at trailer companies. The whole idea is to use something that fills up the whole hole. A bolt only squeezes two pieces of metal together. If you are not worried about retaining everything original looking, the ribbed shank bolts would work fine. They are available from Trailmobile or Wabash or any dealer stocking dry freight van parts. I would weld a patch over the cracked hole, drill it 3/8, put in a rib shanked bolt and it will probably last another 50 years. | | | | | Joined: Feb 2000 Posts: 5,190 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,190 | The rivits are cold, if you watch the video, you can see the guy holding them in his hand. Joe | | |
