Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (TexasJim50, Peggy M, Woodcmiami, farmallb, WICruiser, 66flea), 45 guests, and 4 robots.
Topics128,010
Posts1,055,299
Members48,419
#421991 06/11/2008 3:17 AM
During the restoration on my one ton, I've found the original rivets GM used, but I haven't found what kind of tool GM used to set the rivets, does anyone out there have any idea of the tool GM used and where I can find one? Thanks in advance.....Clint
Stovebolt_six #422001 06/11/2008 3:45 AM
I have installed dozens of frame rivets in sizes up to 3/8" diameter.
This thread explains how I do it with the tools I have available. https://www.stovebolt.com/ubbthread...g&topic=0&Search=true#Post380215
There is a chance that the original ones are set cold with a huge press or cold riveting machine (anyone know for sure?). Unless you have one of those, and can take your frame to it, installing them hot is the way to go.
Check the link above.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #422040 06/11/2008 12:19 PM
Grigg knows what he's talking about... good advice.
I would speculate that they were "squeezed" rather than driven at the factory. It would be faster, the results would be consistent, they could be set without heat, it would only require one worker and the noise level driving rivets with a gun would be insane.
During my years in the aircraft industry I've driven more rivets than I can remember but never anything like a 3/8-inch steel one. I'd plan on practicing a lot, they are not going to go down without a fight.
Unless you are intending a "restoration" I'd recommend just using bolts... that's essentially all a rivet is anyway.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #422214 06/12/2008 12:37 AM
Watch this if you have a fast connection. Its part of a 1937 film from Chevrolet. You can see how they rivit the frames together. Watch the other parts too, its really cool. Joe
http://www.archive.org/details/MasterHa1936_4
Joe H #422221 06/12/2008 12:54 AM
Originally Posted by Joe H
Watch this if you have a fast connection. Its part of a 1937 film from Chevrolet. You can see how they rivet the frames together. Watch the other parts too, its really cool. Joe
Thanks Joe,
That's really neat.
And as I suspected, the rivets are set cold with substantial riveting machines. I priced a modern machine (new) to set cold 3/8" steel rivets, over $20,000 and takes up about as much shop space as my milling machine...
Grigg
---All pictures---
Grigg #422329 06/12/2008 11:38 AM
That is too cool. Still a lot of hand work used in those days.
Drew
DrewP #422364 06/12/2008 1:50 PM
Ex Hall Monitor
Ex Hall Monitor
Kinda neat watching that old video. Similar to how it's still done in aircraft. The larger rivets, and when possible small rivets, are installed using a devise similar to shown in the video. There are a huge number of smaller rivets that are hand driven with a gun & bucking bar and yes Czechman the noise is insane. Hearing protection is required. grin With the advent of fibertow composite body sections the riveting days in aircraft are numbered.
Tiny #422441 06/12/2008 6:22 PM
Has anyone else experienced rivets that are stretched or pulled on the top of the transmission cross-member. On my 1950 3600 the very top rivet set on both sides were either stretched or the bracket cracked. Frame flex in that area?
Brad Allen #422533 06/12/2008 11:28 PM
I'm not sure that frame rivets were cold rivets. They sure look like hot rivets. I am in the trucking business and we repair and rebuild our own trailers. We use aluminum rivets, but I have set 3/8 hot rivets with our riveter. It is like an air chisel with a .498 shank size. We also use Huck bolts. This is a little more expensive. A puller costs around $3000. There are also some ribbed shank siderail to crossmember bolts that are available at trailer companies. The whole idea is to use something that fills up the whole hole. A bolt only squeezes two pieces of metal together. If you are not worried about retaining everything original looking, the ribbed shank bolts would work fine. They are available from Trailmobile or Wabash or any dealer stocking dry freight van parts. I would weld a patch over the cracked hole, drill it 3/8, put in a rib shanked bolt and it will probably last another 50 years.
crenwelge #422598 06/13/2008 1:40 AM
The rivits are cold, if you watch the video, you can see the guy holding them in his hand. Joe
