2 members (ndkid275, Phak1), 58 guests, and 3 robots.
Topics128,089
Posts1,056,004
Members48,430
#419757 06/04/2008 12:34 PM
Does any one have a good photo of the side mount spare tire carrier?
I need to get one for a 1952 3800 long bed.
Just the bracket, no tire,so I can build one if necessary.
Wally
It might not have 100% applicability to your model, but there is a tech tip for a TF mount that might be of help. It has photos (less tire) and dimensions.
I'll go out today and take a pic for you of the one from my 64 if you need it.
dj durant
More pix on Flickr
It's too bad you're not closer. I have one someone made up. It's pretty sturdy, and it's heavy, so it would cost more than it's worth to ship.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
here is a shot of the one that was made for my 50 3/4 ton. should work for your one ton too.
http://good-times.webshots.com/photo/2114090570099732965YWLbKT
near as i can tell it was made from the pieces that use to make up the under bed spare tire carrier.
i've got more shots of this carrier if you are interested.
There's a pretty good picture here in the link below - very similar to the mounts used on the AD's. It's not visible in the picture, but there's a bar that is mounted horizontally on the backside of the bedsides - held on with the lower bolts in the vertical bars. Somewhere here I think there's a good technical drawing of the sidemount setup.
Samantha
http://www.stovebolt.com/gallery/images/taylor_steve_1959j.jpg
1954 Chevy 3100
Picked from the Field
Follow in the DITY
hi there this may be a little off topic but I just bought an original GM spare tire lock hub and bracket for my 54 gmc, has anyone seen one of these before? it has a gm key to unlock and works on my stock bracket. it is made of cast iron. I could post pictures if anyone wanted.
Rayce.
Rayce
1954 GMC 5 window Hydramatic
Rayce,
Would you please post pictures to the lock (on and off the bracket)?
Here's a scan of the diagram for the 1954 side mount spare carrier. The 1953 version had a slightly different shape due to the different shape of the top edge of the bed side.
Also, slightly different bracket "cages" might have been made for different sizes of tires.
Tim
Hi there, sorry i took so long getting these pics on here, I am not to computer smart. here is the link to the photos for the 1950s spare tire lock and bracket
http://community.webshots.com/user/iRayce2?vhost=community&vhost=community
Rayce
Thanks for all the replies.
I'm still looking for the right application, It's a 1951 1 Ton, 9 ft, bed, and a 17" tire.
There is no fender indent as there is plenty of length in that area of the bed.
I'd like to put them on both sides.
This is from my '52 half ton long bed. The round spacer looks like it was welded on by the previous owner but the curved bracket had to be stamped into that shape at the factory. A wheel will fit over the curved bracket alone.
If he had a need to weld on that spacer, it'd be a pretty good bet that this wasn't the original bracket for this truck. I can see how it might fit on a short bed with an indented fender. Anyway, it's different than the other brackets so far. Hope this helps.
Dave
Thanks for the pictures Rayce, that really shows the carrier from all angles. I for one have never seen that type of lock before. I'm restoring a '50 but do work on other years also and will add the pics to my reference file in case it ever pops up.
Thanks for sharing.
By the way DP, that's the saddle, which is part of a 1950 and earlier under bed spare carrier.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Ha!
Fooled me. It fit so perfectly on the side of the bed. The base was even shaped to fit the profile of the running board apron.
Thanks.
Dave
You might be interested in the below link:
Moderator note: An Ebay link was deleted. As the rules of this forum state, they go in their own forum. You guys might as well quit testing me. I'll continue to delete them.
Kent S Butler
'56 Chevy 3100
Houston, TX
Wally - what did you come up with?
I'd like to see the mountings on a one ton !!
1952 Chevy 3804
My 1952 in the Gallery
The only thing necessary for the triumph of evil is for good men to do nothing." - Edmund Burke
