| | | Forums66 Topics128,087 Posts1,055,974 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 80 | Does any one have a good photo of the side mount spare tire carrier? I need to get one for a 1952 3800 long bed. Just the bracket, no tire,so I can build one if necessary. Thanks, Wally | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | It might not have 100% applicability to your model, but there is a tech tip for a TF mount that might be of help. It has photos (less tire) and dimensions. Bill | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | I'll go out today and take a pic for you of the one from my 64 if you need it. | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | It's too bad you're not closer. I have one someone made up. It's pretty sturdy, and it's heavy, so it would cost more than it's worth to ship. | | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | here is a shot of the one that was made for my 50 3/4 ton. should work for your one ton too. http://good-times.webshots.com/photo/2114090570099732965YWLbKTnear as i can tell it was made from the pieces that use to make up the under bed spare tire carrier. i've got more shots of this carrier if you are interested. | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | There's a pretty good picture here in the link below - very similar to the mounts used on the AD's. It's not visible in the picture, but there's a bar that is mounted horizontally on the backside of the bedsides - held on with the lower bolts in the vertical bars. Somewhere here I think there's a good technical drawing of the sidemount setup. Samantha http://www.stovebolt.com/gallery/images/taylor_steve_1959j.jpg
| | | | | Joined: Jun 2008 Posts: 8 New Guy | | New Guy Joined: Jun 2008 Posts: 8 | hi there this may be a little off topic but I just bought an original GM spare tire lock hub and bracket for my 54 gmc, has anyone seen one of these before? it has a gm key to unlock and works on my stock bracket. it is made of cast iron. I could post pictures if anyone wanted.
Rayce.
Rayce 1954 GMC 5 window Hydramatic
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Rayce, Would you please post pictures to the lock (on and off the bracket)? Here's a scan of the diagram for the 1954 side mount spare carrier. The 1953 version had a slightly different shape due to the different shape of the top edge of the bed side. Also, slightly different bracket "cages" might have been made for different sizes of tires. Tim | | | | | Joined: Nov 2007 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 80 | Thanks for all the replies. I'm still looking for the right application, It's a 1951 1 Ton, 9 ft, bed, and a 17" tire. There is no fender indent as there is plenty of length in that area of the bed. I'd like to put them on both sides. | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | This is from my '52 half ton long bed. The round spacer looks like it was welded on by the previous owner but the curved bracket had to be stamped into that shape at the factory. A wheel will fit over the curved bracket alone. If he had a need to weld on that spacer, it'd be a pretty good bet that this wasn't the original bracket for this truck. I can see how it might fit on a short bed with an indented fender. Anyway, it's different than the other brackets so far. Hope this helps.
Dave
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks for the pictures Rayce, that really shows the carrier from all angles. I for one have never seen that type of lock before. I'm restoring a '50 but do work on other years also and will add the pics to my reference file in case it ever pops up. Thanks for sharing.
By the way DP, that's the saddle, which is part of a 1950 and earlier under bed spare carrier.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Ha!
Fooled me. It fit so perfectly on the side of the bed. The base was even shaped to fit the profile of the running board apron.
Thanks.
Dave
| | | | | Joined: Nov 2006 Posts: 37 New Guy | | New Guy Joined: Nov 2006 Posts: 37 | You might be interested in the below link:
Moderator note: An Ebay link was deleted. As the rules of this forum state, they go in their own forum. You guys might as well quit testing me. I'll continue to delete them.
Kent S Butler '56 Chevy 3100 Houston, TX
| | | | | Joined: Mar 2008 Posts: 131 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 131 | Wally - what did you come up with?
I'd like to see the mountings on a one ton !! 1952 Chevy 3804My 1952 in the Gallery The only thing necessary for the triumph of evil is for good men to do nothing." - Edmund Burke | | |
