7 members (DavidBraley, Otto Skorzeny, J Lucas, 66flea, Rosco, 55shaker, 1 invisible),
122
Mod | | | Forums66 Topics128,283 Posts1,058,504 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | We had the hood hinges powdercoated, now the hood will not stay up on it's own. Could the heat from powdercoating affected the tension in the springs? Went to our first cruise Saturday and had to use a hood prop to keep the hood up. Any way to adjust the springs? Hate to buy a new set of hinges. Hood fits perfectly, but just won't stay up!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hinges need friction between the parts at the rivets that pivot them, I don't think powder coating would be a good thing ... the easy test would be a new set of springs, but I'd think the hinges are the problem
Bill | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | There's no way to adjust the springs that I know of. Powder coating gets to about 400deg F. I don't know if that would rob the springs of their temper or not. I replaced several hood hinges back in the day & the new ones didn't have a LOT of friction at the joints but Bill could be right about the springs being designed for a little. I agree that the true test would be replacing the springs with new (uncoated) springs & see what happens. If you want them colored you might try some spray paint.
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Coach, I put brandy new hinges on mine, whatever finish came on em i left as is ...an they BARELY hold my hood open..you jossle the truck around with the hood up it will come down quick!...Im just wonderin if the aftermarket hinge springs are just THAT aftermarket JUNK?...or are yours factory? Tim | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Mine are factory, Tim. They were OK before the powdercoating, but now they won't hold at all. I guess I will just use the prop rods for awhile. I hate to mess with the hood again since we got a nice fit the last time! | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | Mine are factory, Tim. They were OK before the powdercoating, but now they won't hold at all. I guess I will just use the prop rods for awhile. I hate to mess with the hood again since we got a nice fit the last time! Did you coat the springs? Do you have any current pics of the hinges with springs?
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Yes , we did coat the springs, will take some photos and post them. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | Hood hinge springs used to be a dime a dozen at the salvage yard. Prolly hava hard time finding them now though.
| | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Try Hoodagra.
WARNING: If your springs can't keep your hood up more than 4 hours, please see a mechanic. Although hood openings lasting for more than 4 hours may occur rarely, as with all spring treatments in this repair class please be careful. To avoid long-term injuries, it is important to seek immediate mechanical help.
The most common side effects of Hoodagra are blocked vision, getting mad, and upset wallet. Less commonly are bluish vision, blind spots and or sensitivity to jokes about Hood Disfunction may briefly occur.
I AM SO SORRY, I just could not resist. I'm surprized no one beat me to this, esp. with some of these serious jokers!
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | As part of looking at the nifty new bed you made for your granddaughter, I saw the pictures of your hinges. I think you may have them swapped from side to side. Doesn't the spring go outboard? As you have them mounted, the spring will hit the firewall and not allow the hood to go completely up. | | | | | Joined: Nov 2008 Posts: 104 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 104 | I have my hinges mounted the same way you do, coach-frank, and my hood stays up just fine. By the way, I hope my 53 looks half as good as yours when I'm done with it. You have one fine looking bolt, and should be proud of the job you have done! | | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | I think Tmater might have a good point here. The hinges don't look like they are fully extended. There is a little tab that touches one of the pivoting arms on my hinges when they are up all the way. Just checked. If mine aren't up fully, the hood does not stay up. By the way I have the spring facing the same way as yours. Doesn't necessarily mean it's right though. | | | | | Joined: Oct 2009 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 83 | Could it be the wrong springs?
1999 GMC Yukon 1957 GMC 100 Panel
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I don't think so Doug9656, all the 1/2 to one ton trucks are the same parts, I don't know if the big bolt hinges would be different or not. | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | This topic is almost 1 1/2 years old - I think he's already fixed it by now. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Yep I fixed it by picking up a used set of springs and painting them. I still believe the powder coating caused them to loose their tension and strength. I put the new springs on the same way and now the hood stays up. Thanks Guys! Coach Frank | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | oops, I looked at the month/day but ignored the year. | | |
