1 members (wvstovebolt),
31
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 7 New Guy | | New Guy Joined: May 2008 Posts: 7 | I am going to restore a 1946 2 ton Chevy that my employer bought and we have a Kansas title for it, but it has no VIN plate on the truck and the VIN number on the title is a odd number that starts with DEA and then has a 6 digit number. I know that the DEA number is part of the engine numbers. Also what do you do for a VIN plate because I haven't looked a lot but I haven't seen a repro. Help! Thanks and GOD BLESS. Terry H. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Find another truck with proper paperwork and tags, then the one you have now becomes a "parts truck" for the one with the paperwork.
It may seem a bit extreme, but depending on the hoops you have to jump through to get a title problem straightened out.. You may look back and say, "Wow, I should have bought that wreck down the road with good paperwork, sure would have been less trouble"
Grigg
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | just to be sure you looked in the correct place. id plates would be located on the passenger side cowl under the hood. some states used engine number for titling and registration purposes in years past. | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | Many states such as Texas titled vehicles by motor number before 1955. Back in their day, when a different engine was installed, the number which appeared on the title was stamped on the distributor boss. | | |
