2 members (Gdads51, 1 invisible), 92 guests, and 0 robots.
Topics128,052
Posts1,055,743
#417516 05/28/2008 12:54 PM
thanks to a fellow bolter..He tells me that on my 46 panel the rear fender welting is wide and flat and the fender bolts go
through the welting..It's not the kind with the bead on it..
I have been looking through some books but can't seem to find
a supplier of this kind of welting...Any idea's...thanks in
advance....jd
1946 chevy 1/2 ton panel
1937 ford coupe
the original is flat on my 52 panel the same as yours. However I do "think" the felt is out there??!! It seems I did see where someone offered it?
After looking at mine I had the thought of using some of the 30# roofing felt that is used under shingles. I don't know if it'd work or not but it sure came to my mind when I looked at the original.
A little off topic (since the discussion has moved into Advance-Design trucks): I'll check the 47-54 Factory Assembly Manual tonight, but I think the 47-54 rear fenders on pick-up bodies did not have any fender to bed gasket/welt/felt. Nonetheless, many people used a heavy-weight roofing-felt as a seal; and, Jim Carter sells beaded welting for the A-D rear fenders. However, the 47-54 panel-body rear-fenders had beaded fender-welt as was standard for the front fenders (a small bead).
Jim Carter seems to indicate that a fender welt was not originally used on 34-46 fenders (front or rear) but he sells the 47-55 beaded felt as a non-original "extra" (for front and rear).
JDHOWARD,
Buy the welting with the bead and trim off the beaded edge. Saves trying to find an alternative!
I've been trying to find the same stuff here in Australia for 5 years now and have come to the same result...can't find nought!
I've ended up with 1/8 inch thick rubber strips that I have hole punched the bolt holes into.
Easiest way to go I reckon!
Best of luck...........Doc Bob.
"It's not a wreck......It's a natural resource!"
Quote-Doc Bob circa 2006
DOCS CLASSIC GARAGE
Specializing in Hot Rods,
Customs & Street Machines.
My pictures at..........
1936 Chev 1/2-Ton Holden Body
confused? http://www.koalanet.com.au/australian-slang.html
For what it's worth, my 51 panel apparently had beaded welting. While the bead is now gone, when the truck was repainted in the company colors that the PO used, there must of been a bead, because along the joint between fenders and body is a area of about 1/4 inch on each side that is the original color. My guess is that the bead was there when it was painted and then eroded away over time.
1951 Chevy 1-Ton Panel
Pictures of the restoration on Photobucket
RIP good friend.
TheNed: Same thing must have happened to mine as there is no "bead" on it. Mine appears to have seen a pretty rough life or should I say "used for what it was built for". smile
Leo Offline
Moderator
Moderator
My personal preference is the non-beaded welting. I hadn't thought of using felt paper or rubber strips. I have easy access to reams of rubber strips, may go that route.
Leo #418643 06/01/2008 1:01 AM
why use any than ?!
care to chat write back
