3 members (Dennys28, Ponchogl, Oswald), 66 guests, and 1 robot.
Topics128,051
Posts1,055,766
#417733 05/29/2008 2:07 AM
They say necessity is the mother of invention. Well, I had no help and needed to remove the cab from the frames today. Here is a shot of how I did it.
http://good-times.webshots.com/photo/2305176350103486525bOenSM?vhost=good-times
I nailed together a couple of 2x4's and stuck it through the door frame. Took some experimenting to get the center of gravity right, but once I did, the cherry picker lifted it straight up. No strain!
Now on to the dreaded body work.
http://community.webshots.com/user/49chevyman?vhost=community
"The only people who do not make mistakes, are people who do not do anything."
Y
Y Offline
Great job, and they said it couldn't be done
Tempe, AZ
Bill S.
Tempe, AZ
Wow, well done!
But what happend to the front window, was is broken before?
And what was the next step after lifting up? As far as I can see, there is no possibility to move neither the cherry picker nor the frame?!
AJ
'59 Apache
'67 Mustang
ODSS President
ODSS President
Nice, my guess is slowly roll her out towards the camera and then set her down on your home-made-roll-around cab stand.
~ Cosmo
1949 Chevy Half Ton
COSMO is righton to what I did on my 3100. That's how I lifted and moved my cab away from the frame,although I was outside with more room and I hooked a cinch strap to help keep the cab from swinging side to side too much.
Drew
AAAAH the mother of invention!
1952 Chevy Shortbed
Photos in Photobucket
I basicly did it the same way except I ran the 2X's in an X pattern from the rear corners of the cab to under each corner of the dash. Bolted them together with an eye bolt in the center, then ran a strap from the center to a eyebolt in the floor for stability. I also added weight to balance it out.
Either way it works great.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
Yeah it just rolled back towards the camera and I set it on my wooden frame on rollers.
Now - how do roll it over so I can work on the bottom ? Any creative solutions to that one ? Show me some pictures if you have any.
I thought of bolting a wooden frane to the firewall and just tipping it over, slowly of course. I would like to get the floor pan work done first. I am going to probably use Herculiner on it. Then I will clean up the firewall, then the rest of the cab.
You can rest it on the firewall or the back just take it easy when you tip it. Here's my pic's of that:
http://rides.webshots.com/album/377692314ehfoan?start=0
Have fun.
You Tube
Pretty slick-I just bought one last year to pull my engine ..I can see it has many uses...gonna try it to put my tranny in thru the cab...think you can pull stumps with it?
Keith
Pull stumps...that is what the truck was made for!
Curt - thanks for the ideas. I like that shade of blue. I think I will rock it over on the firewall instead of the rear of the cab. The rear does just not appear to be sturdy enough.
Camp Commandant
Camp Commandant
I read where someone rolled their cab onto and old mattress without damaging it, I never tried it though.
~ Billy
1959 GMC 860 | Pictures
I rolled mine on an old carpet then slid it to the back of the frame, spun it then tipped it onto my dolly. I did it twice by myself. I would recommend just getting a few helping hands over and lifting it off though. It was not the best hing I could have done for the cab or my back... fortunately nobody got hurt.
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
Great pictures guys.
~Jim
Very creative!
Robert C.
I'm a Genius in the making.
1950 3600
