4 members (klhansen, 1955 1 Series, Lightholder's Dad, ShopRag), 163 guests, and 0 robots.
Topics128,209
Posts1,057,461
Members48,471
jdl
Offline
First off, I'm trying to reconnect the passenger side wiper. It was disconnected by one of the po's and I tried to figure it out but didn't get very far.
Secondly, I have to replace my sending unit due to it being clogged completely, no getting the gunk out of that, and plus it's in bad shape, with the band that connects to the float being broke off on one side. Which company has the best one? I went to my local store and they didn't know where we could get one.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl
Offline
Well, I forgot to mention that I needed info on how the wiper motor arm thing connected to the wiper arm.
Jordan D. Long
Photobucket
Jordan, can't exactly answer your questions here but have you looked at the online manual link? It may have a pic or two in it and you know that "a picture is worth a thousand words".
I'm sure you can get the parts you need from JimCarter...or other vendors like AMerican Classic
jdl
Offline
Well, I've looked in my shop manual but the only thing it shows is how to get the arm off of the rod that goes through the cowl(if that is the right word) below the windshield. The rod that goes through below the windshield is connected at a joint to another rod(flatter wider piece of metal, whereas the rod that goes through below the windshield is round) that goes to the wiper motor. This joint is my problem. That's where it was disconnected, and the weird shaped piece of metal that has the flat rod connected at one end has a hole for the round rod(I know this is hard to understand but I'm doing the best I can to explain) to go through. The round rod has some of the material removed on the end to make it rectangualar so that it can fit through the hole in the metal piece at the joint. I'm not sure how to go about keeping that rod attached to the piece of metal that makes up the joint.
Jordan D. Long
Photobucket
Y
Y Offline
JDL, just sent you a PM with pic. Let me know if I can be of any more help. The other end of the rod "smaps" over the ball on the wiper motor rod.
jdl
Offline
Yakimabowtie, thanks for the picture, but it's the other side where the wiper arm goes through the cowl that is the problem. The part where the glove box should be, but I don't have a glove box so I can see what I'm talking about. You'd probably have to take yours out to see what I'm talking about.(if you have one)
Jordan D. Long
Photobucket
jdl
Offline
Anywho, I got it on, but I'm not sure how good it is going to stay on.
Jordan D. Long
Photobucket
