4 members (Goach2, JW51, BC59, 1 invisible),
102
Mod | | | Forums66 Topics128,092 Posts1,056,457 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I picked up a July 2008 issue of "Hot Rod Deluxe" off the magazine rack the other day. It seems to be a magazine geared towards retro and old rods. I think it would be an issue most Stovebolter's would enjoy.
Inside it is a great rebuild article on the Blue Flame 235 cu in engine. It claims that this rebuild gives the following:
Peak torque Arpm: 217.0 lb-ft @ 2400 Peak Power @ rpm: 132.1 hp @ 4000 Average torque: 198.4 lb-ft Average power: 111.9 hp | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Thanks, I will definitely pick it up. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Sounds good. I'll look for it too. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Glad you guys liked the issue--I'm doing some work for Hot Rod Deluxe now; that's my story on the gasser rear suspension. In the last issue, I had a shot of my '62 Suburban under a sign that said "Rust College."
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Hey Brad54, I'll keep that suspension article for my 57 delivery.  | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | What are the differences between a Blue Flame and a Thriftmaster is it the years of production or car VS truck??....Thanks | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | | | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Goes deeper then just car vs. truck. The Blue Flame was the first engine installed in the Corvettes, until they started using V8's. The Blue flame had three 1bbl side-draft carbs, and maby a different head that gave it some more umphhh making it the classic little roadster every one feel in love with. Here is alittle info from Wiki. Chevy 235 L6 on Wiki
58' 3200 235 3-speed/OD
