3 members (Gdads51, Raymond HAYWOOD, IHPWR), 175 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#357803 01/08/2008 1:35 AM
The passinger side door latch has to be pushed down to open the door, but on the drivers side, you lift up. I never really noticed that before, is it normal for these trucks or did the PO do something different?
Jolly pointed out that if you were to lean on it, you'd open the door and possibly fall out.
Gee, I really wouldn't want that to happen to the wife, she'd think I did it on purpose wink.
I never ride on the passinger side, so I never noticed, I mean I've only had the truck over a year, oh duh.
Jake
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
jake, you didn't say but could it just be that someone put the door handle with the end facing toward the front of the truck (to push it down) instead of pointing to the back of it (to pull it up) Understand???
AChipmunk,
I don't think so, because if you sitting in the pass. seat the handle would be grabbed by your right hand and the first thing you would do is pull it toward you/pull it up. Imagine the face of a clock with the #9 being centered. It seem to me (I'll pull the cover in a few days) That the latch bar connected at the bottom would pull away from the rear of the door area releasing the lock/latch? Pushing down on the handle should engage the bar to push against the lock/latch to jam or force it to lock.
I'll take a look at the posistion of the handle as how it sits tonight, loosen the set screw and try and reposition it, but I don't think that will mater because the pivot shaft still would act the same. (Does that make sense?).
The only thing I can figure is that when the PO installed the pivot it was put in at the wrong angle and the latch bar is at the top instead the botton of the pivot point. and it woud act in reverse. I'll let you know later.
Jake
my 42 the driver pushes down and passenger lifts up
Keith and Kim
1942 Chev 3/4-Ton Flatdeck in the Gallery
Victoria, BC, Canada
I just went outside and checked mine out, both my driver side and passenger side lifts up.
Just went out and checked my ‘41. Both handles extend toward the back of the cab and both push down to open. That is the way they were when I got the truck. They could easily be changed to extend forward and pull up. Anyone know which is correct ??
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
We figured it out. The stock way to mount the pass. side handle is it faces the 5 O'clock position and you life it upwards and backwards. Strange but safe. You push it toward the 6 o'clock position to engage the lock.
my 57 handles are both the same. 7 o'clock is idle, pulling toward 6 o'clock opens door, and pushing toward 9 o'clock locks the passenger door.
1957 Chevy 3100 1/2-Ton
Photobucket pictures
I have a 66gmc and my passenger side door handle dose not seem to lift the latch far enough to open the door from the inside,But you can open from the outside.And yes if you push it down it will lock the door.Anyone know why this is.Please let me know.
Bruno,
Pull the c0over and see if the bar bas bend before it goes through the rear (CAB SIDE) hole, if they get bend just a little they won't reach enough.
Jake
Hay jake,I,ll will look at that bar you talking about and see if it has been altered at all.Thanks for the tip.
Moderated by  ndkid275, Phak1
