9 members (treegrower, 68ironhead, GRNHydra, Nhluvstruck, 55shaker, MickeyP, elhippie64, David Bush, 1 invisible),
43
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | The passinger side door latch has to be pushed down to open the door, but on the drivers side, you lift up. I never really noticed that before, is it normal for these trucks or did the PO do something different? Jolly pointed out that if you were to lean on it, you'd open the door and possibly fall out. Gee, I really wouldn't want that to happen to the wife, she'd think I did it on purpose  . I never ride on the passinger side, so I never noticed, I mean I've only had the truck over a year, oh duh. Jake
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | jake, you didn't say but could it just be that someone put the door handle with the end facing toward the front of the truck (to push it down) instead of pointing to the back of it (to pull it up) Understand??? | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | AChipmunk,
I don't think so, because if you sitting in the pass. seat the handle would be grabbed by your right hand and the first thing you would do is pull it toward you/pull it up. Imagine the face of a clock with the #9 being centered. It seem to me (I'll pull the cover in a few days) That the latch bar connected at the bottom would pull away from the rear of the door area releasing the lock/latch? Pushing down on the handle should engage the bar to push against the lock/latch to jam or force it to lock.
I'll take a look at the posistion of the handle as how it sits tonight, loosen the set screw and try and reposition it, but I don't think that will mater because the pivot shaft still would act the same. (Does that make sense?).
The only thing I can figure is that when the PO installed the pivot it was put in at the wrong angle and the latch bar is at the top instead the botton of the pivot point. and it woud act in reverse. I'll let you know later.
Jake
| | | | | Joined: Jan 2007 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 63 | my 42 the driver pushes down and passenger lifts up | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | I just went outside and checked mine out, both my driver side and passenger side lifts up. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Just went out and checked my ‘41. Both handles extend toward the back of the cab and both push down to open. That is the way they were when I got the truck. They could easily be changed to extend forward and pull up. Anyone know which is correct ?? | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | We figured it out. The stock way to mount the pass. side handle is it faces the 5 O'clock position and you life it upwards and backwards. Strange but safe. You push it toward the 6 o'clock position to engage the lock.
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | my 57 handles are both the same. 7 o'clock is idle, pulling toward 6 o'clock opens door, and pushing toward 9 o'clock locks the passenger door.
| | | | | Joined: Feb 2008 Posts: 13 New Guy | | New Guy Joined: Feb 2008 Posts: 13 | I have a 66gmc and my passenger side door handle dose not seem to lift the latch far enough to open the door from the inside,But you can open from the outside.And yes if you push it down it will lock the door.Anyone know why this is.Please let me know. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Bruno,
Pull the c0over and see if the bar bas bend before it goes through the rear (CAB SIDE) hole, if they get bend just a little they won't reach enough.
Jake | | | | | Joined: Feb 2008 Posts: 13 New Guy | | New Guy Joined: Feb 2008 Posts: 13 | Hay jake,I,ll will look at that bar you talking about and see if it has been altered at all.Thanks for the tip. | | |
