8 members (MRMEROTH11, Peggy M, Southerntruck, Jon G, Ponchogl, Oswald, moparguy, Hanks custodian),
123
0
Mod | | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 1 New Guy | | New Guy Joined: May 2008 Posts: 1 | Need banjo bolts for a 71 C50 with 7000lbs front axle with dual wheel cylinders. I can Find everything else but these, does anyone know where to find them? One is sround 3 inches long and the lower one is normal | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy macpaul, bolt, front brake hose connector p/n 2449792, Wagner p/n FC42100 bolt, front wheel brake cylinder p/n 2253937, Wagner p/n FC11409, I couldn't cross either of those part numbers into Napa numbers, hope that helps | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I recently looked for an ordinary banjo bolt at my NAPA, and they are good at finding things, but no luck finding banjo bolts.
Some of the aftermarket brake line folks, like Classic Tube, and Inline tube, may have some. If you had a sample or sketch you could also have some made, if that is your last choice send me a PM, I can probably help.
Grigg
| | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | I recently looked for an ordinary banjo bolt at my NAPA, and they are good at finding things, but no luck finding banjo bolts. My NAPA didn't have any problem with banjo bolts and crush washers for my GMC 350 but no one had the brass block fitting that they go with. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | That's funny, my NAPA had some of the brass blocks/adapters to inverted flare, but no bolts... | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Sounds like the two Napa stores should share some inventory | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | macpaul: JimCarter carries some so check them out. I've seen the blocks and bolts in their book recently. http://www.oldchevytrucks.com/cgi/htmlos.exe/start.htm | | |
