3 members (55shaker, Jon G, BillCollins), 133 guests, and 2 robots.
Topics128,080
Posts1,055,956
Members48,430
#413035 05/14/2008 11:23 PM
Need banjo bolts for a 71 C50 with 7000lbs front axle with dual wheel cylinders. I can Find everything else but these, does anyone know where to find them? One is sround 3 inches long and the lower one is normal
macpaul #413077 05/15/2008 1:23 AM
3B Online: Content
3 Online: Content
Hy macpaul, bolt, front brake hose connector p/n 2449792, Wagner p/n FC42100
bolt, front wheel brake cylinder p/n 2253937, Wagner p/n FC11409, I couldn't cross either of those part numbers into Napa numbers, hope that helps
3B #413104 05/15/2008 2:36 AM
I recently looked for an ordinary banjo bolt at my NAPA, and they are good at finding things, but no luck finding banjo bolts.
Some of the aftermarket brake line folks, like Classic Tube, and Inline tube, may have some.
If you had a sample or sketch you could also have some made, if that is your last choice send me a PM, I can probably help.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #413150 05/15/2008 5:00 AM
My NAPA didn't have any problem with banjo bolts and crush washers for my GMC 350 but no one had the brass block fitting that they go with.
That's funny, my NAPA had some of the brass blocks/adapters to inverted flare, but no bolts...
Grigg #413227 05/15/2008 5:37 PM
Sounds like the two Napa stores should share some inventory
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
macpaul: JimCarter carries some so check them out. I've seen the blocks and bolts in their book recently.
http://www.oldchevytrucks.com/cgi/htmlos.exe/start.htm
