0 members (),
256
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | And are they worth it? I've been having problems with my points in the distributor and Tabdoo16 told me that they were worth the money, but I'd really like to know if they ARE actually going to eliminate the hassle of points. What are your experiences? NOTE: Not going to buy them right now, because my starter doesn't work, just want an idea if they are worth it. | | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | They work great and take a lot of guesswork out of your ignition system. The directions are pretty good and are easy to follow,
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Try a search on "PerTronix" and you'll find lots of testimonials.
"I'd really like to know if they ARE actually going to eliminate the hassle of points."
No condenser; no points to adjust/replace; what other hassles are there with having points?
I've been using them in a 12v for 10 years and in a 6v for 4 years; and, I will soon be putting a Pertronix unit in a 6v positive-ground GMC truck. | | | | | Joined: Mar 2008 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 43 | I've used many of them on GM V8s. Others will disagree, but I think they are the best upgrade ever. I have not tried them on the bolts yet. Very simple too.
Spencer
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Thanks guys. When I get my starter working again I think I might get some. | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Well worth the money. No more points to hassle with. | | | | | Joined: May 2008 Posts: 194 Shop Shark | | Shop Shark Joined: May 2008 Posts: 194 | I use it on my 57 3100 V8. On the V8 it is a bit harder to install as you need to pull the distributer and pull the pin and put a shim at the bottom of it. Then install a new pin. They do not tell you this until you read the detailed instructions. I used this one for the 283 v8 http://www.shopatron.com/product/part_number=1181/591.0.26484.26485.0.0.0Other than that I did not like having to worry about the proper air gap between the ring and the sensor. You have to add washers to adjust the gap. I think I still have an issue as when the engin gets reall warmed up and I try higher RPM it seems to miss a bit since the distributer shaft lengths just a tad from heating up and the air gap increases. I need to put a nother set of washers in there. But as far as having it start, it is great. I do not run my truck often and with the old points I had to clean them to get it to start or adjust them or de-pit them every 3 months. With the pertronics it just starts, even after sitting 6 months or more. pretty simple. Now they have an Ingniter II that seems they still have the same ring. But it is smarter and may adjust for some of the issues I am seeing. http://www.shopatron.com/product/part_number=91181/591.0.26484.26486.0.0.0You might consider going for the correct igniter II version for your install. You can start searching here: http://www.shopatron.com/index/591.0.26484.0.0.0.0 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I do not think that there is "correct" Ignitor II for a 41-62 Chevrolet 216/235/261 engine. The original PerTronix Ignitor is available for 41-62 Chevrolet and 39-62 GMC engines (6 and 12v volt; positive and negative ground). $89.95 Make sure you get the right part number to match your style of your distributor. 1167, 1167N6, 1167P6 1168, 1168N6, 1168P6 | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | The 1168 series Fits 1954-1962 Chevy 6 with standard single point ignition, except with dist. # 1112314
1168 for 12 volt 1168N6 for negative ground 6 volt 1168P6 for positive ground 6 volt
Before you order online, I would check with your local parts house.
1168N6 online at PerTronix is $111.06 plus shipping. Local parts price is $97.30.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Put new points and condenser in the 49 last weekend. First in 5 years. Truck always ran smooth and started fast. Runs smoother now and starts faster. Having said that I don't think I would rule out converting in the future. Someone said that in the instructions it tells you to keep your old points in the glove box in case. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | I've had one in my 6V 1952 216 for about 4 years with no problems. Shop around for the best price.
Ed
