1 members (Gdads51), 84 guests, and 3 robots.
Topics128,139
Posts1,056,447
Members48,441
#41063 06/25/2004 5:37 AM
I put 3" lowered coil springs on my 65 chevy today and when I jack it up by the frame where the control arms are just hanging there the coil springs are loose. I dont have the front drag link hooked up or shocks on it. Is it normal for these coil springs to be loose like that. Thanks
#41064 06/25/2004 3:29 PM
That's the way my 64 is with 2 coils cut outta the front springs.
#41065 06/25/2004 7:04 PM
so that isn't something that I need to be concerned about. They won't ever come loose when I am driving will they or If I hit a big pothole in the road?
#41066 06/25/2004 7:13 PM
Brady, I'm a little reluctant to reply to this one, after all the flak on your other post, but I'd reccomend putting on some sort of travel limiter to prevent problems on a sudden, hard bump. We use a steel cable on the race car suspension to keep the springs from getting out of shape, mostly when jacking the car for wheel changes, etc. If you use the right length of shock for your ride height, the shock will establish the lower limit of suspension travel before the springs get out of shape.
#41067 06/25/2004 7:37 PM
Ha thanks for the post Hotrod I don't think that this topic will be as hot. I haven't bought the shocks yet but I was hoping that that would be what would keep them tight. I just wasn't sure if that would be too much pressure on the shock. I might look into the steel cable option for a little extra support if needed. thanks again
#41068 06/26/2004 3:53 AM
Put fresh rubber snubbers on to limit the suspension travel. Won't go any further (Hotrod) so to keep my butt out of trouble too,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
