0 members (), 135 guests, and 3 robots.
Topics128,089
Posts1,056,440
Members48,443
#408368 04/30/2008 4:19 PM
Ok, I searched and could not find, so...
I have a SM420 from a 52 long bed with a torque-tube drive line. I need to couple it to an open drive-shaft which will connect to a mid '70s 3/4 ton rear-end. I've seen pictures of an SM420 online with this desired setup. Can anyone share any knowledge of an aftermarket or later model rear transmission cover plate that will couple to an open drive-shaft u-joint yoke?
Thanks. This website rocks!
Dave
Any chevrolet or gmc truck with an sm420 newer then 1955 should have the proper rear cover and yoke that you want. They used this tranny through 1967 and even into the 1980s on some larger trucks and military trucks.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Sorry, I forgot to mention that this truck had a 58-60 something 235 in it, and I assumed that the transmission was also non-original since I've never seen this 4 on the floor setup with any other 52 GMC's.
So later model 420's came with an open drive-line setup? Maybe this thing is original then.
Thanks.
Dave
Is your truck a 1/2 ton long bed or a 3/4 ton?
You mention you are putting in a later 3/4 ton rear...
If your truck is a 3/4 ton you already have an open drive shaft from the carrier bearing on back.
Steve
'49 3800
'52 3600
'57 3100
Steve, it's a 100 series, longbed, '52 GMC. (1/2 ton)
So the 3/4 tons came with open drive-shafts before 1955?
Dave
Wondering why you want to put a 3/4 ton rear in it?
3600's had a 2 pc. drive shaft with the front being torque tube and the rear open.
Steve
'49 3800
'52 3600
'57 3100
The 3/4 ton rear-end I have has a nice gear ratio. 3.11 or 3.07 to 1 (I forgot which).
Dave
Larger trucks with an SM420 had open drive also. There should be a lot of open drive type SM420's out there, and you can either swap the entire transmission or just the pieces at the back.
Another reason I used that rear end is so I can use my original wheels (it's a six lug).
Well, thanks guys. I'll get on ebay and see what I can find.
Dave
Dave
6 lug 3/4 ton?? Would have to be an '88-'94 14 bolt semi floater, anything before that would be 8 lug.
Bill Burmeister
I've got an open driveline SM420 in my garage that I'm not using, PM me if you want to buy it.
Paint & Body Shop moderator
That rear is going to be a little wide for your truck.
I think the 6 lug 3/4 tons went a little later than '94.
I just retired a '96 3/4 ton shop truck that was a 6 lug.
Over 325,000 miles on the same engine, no rebuilds!
Steve
'49 3800
'52 3600
'57 3100
Just an update in case anyone searches this topic:
The rear end was a 1/2-ton six-lug 3.07:1.
I went to Novak trans parts and got some rebuild parts along with the open driveshaft rear trans plate cover. Still haven't found a drive shaft. It has to be a 2 peace (with the slip splines between the u-joints) because the yoke at the transmission is fixed. I might have to go to a shop to have one custom built.
Dave
