4 members (Gdads51, DadsFirstPickup, 3B, Joe H), 79 guests, and 2 robots.
Topics128,118
Posts1,056,305
Members48,439
#403196 04/17/2008 1:00 AM
Does the fender welting on a 46 panel have a bead on the fender
side or is it just a flat piece of rubber that goes between
fender and body...there is nothing at all on mine when I took
the fenders off...thanks in advance
1946 chevy 1/2 ton panel
1937 ford coupe
the welting on got from American Classis has the bead on the outside. I got the chrome and it doesn't look bad on it.
David
Just a firefighter,
Cleverly disguised as a responsible adult
'46 1/2 T Panel
JDHOWARD,
My 46 panel (yet to be worked on) has welting but there is no bead. This doesn't mean that it never had a bead but that there is no sign of it now. Wish I could help more.
All the best, Ted
jdhoward: I pulled off a set of original fenders from my 52panel. There was some "welting" but it is flat and does not have a bead. It actually looks like a piece of flat thick roofing felt. Just because I like it for the accent I do plan on putting it back in but with the bead.
k10 Offline
Original GM welting from the 41-46 era had no bead. If you are painting fenders black and body another color, then beaded welting will be fine, but in my opinion a light colored one-tone truck just looks awful with a black bead defining the fenders. It's too new looking and is obviously a reworked truck. JM2Cents
