| | | Forums66 Topics128,091 Posts1,056,037 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | Does the fender welting on a 46 panel have a bead on the fender side or is it just a flat piece of rubber that goes between fender and body...there is nothing at all on mine when I took the fenders off...thanks in advance
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | the welting on got from American Classis has the bead on the outside. I got the chrome and it doesn't look bad on it.
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | JDHOWARD, My 46 panel (yet to be worked on) has welting but there is no bead. This doesn't mean that it never had a bead but that there is no sign of it now. Wish I could help more.
All the best, Ted
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | jdhoward: I pulled off a set of original fenders from my 52panel. There was some "welting" but it is flat and does not have a bead. It actually looks like a piece of flat thick roofing felt. Just because I like it for the accent I do plan on putting it back in but with the bead. | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Original GM welting from the 41-46 era had no bead. If you are painting fenders black and body another color, then beaded welting will be fine, but in my opinion a light colored one-tone truck just looks awful with a black bead defining the fenders. It's too new looking and is obviously a reworked truck. JM2Cents | | |
