2 members (NJC, greenie-reddy), 159 guests, and 4 robots.
Topics128,260
Posts1,058,287
Members48,485
#406891 04/26/2008 9:13 PM
Will a 1955 GMC 235 and 3speed tranny bolt up in a 1957 Chevy without modification, or is the GMC not a 235?
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
Most likely the 1955 GMC engine is 248 ci GMC engine, if it came off a 1/2 ton GMC USA-made truck.
The GMC engine is longer than the Chevy engine. Maybe someone will post information about how hard it would be to install the 235 in a 1957 GMC truck.
Figure out exactly what the GMC motor is first. If its a 270 or 302 you have something worth the trouble to swap.
Thanks for the info. I am looking to change out my 235 without having to modify anything.
Does anybody have any experience installing a GMC 228 where a 216 once was?
I plan to use the 216 bell housing to get the rear mounts right but length is my problem,GMC is a little longer. So the wiggle room (if any) is up front.
Should I just move on to a 235?
murraydave
I've seen this done and while not that difficult a swap, the real easy bolt-in for this is a 261 Chevy. The GMC will bolt right up to the 216 or 235 bellhousing this is the easy part.
Another real problem is finding a good GMC without a cracked head or block.
First what every car or truck the longer GMC is going into will need more room up front so see if you can re-mount that radiator forward. Also you can eliminate the GMCs fan and put an electric pusher in front of the radiator, saving a couple inches. Anything can be done if you want it bad enough to solve the few problems.
1946 1/2-Ton Chevy
Alan,
If it's a 1955 GMC 248 the block casting should be 2324002.
Looks like 1955 was the last year for the 248.
-Tom
1950 Chevy 3100 w/ 1956 235
