1 members (Wooley),
105
0
Mod | | | Forums66 Topics128,151 Posts1,056,997 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 8 New Guy | | New Guy Joined: Apr 2008 Posts: 8 | hello I just picked up an old gmc truck. I really liked it so I bought it, but I have no idea what year it is or how to find info about it. any help would be appreciated. I have never seen a truck like this before. steve [IMG] http://i31.tinypic.com/xdv092.jpg[/IMG] | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | pretty interesting some of the folks with more knowledge will be along. the hood and cowl don't appear to be to badly bent.similair to the one maxx posted but yours appears to have pneumatic tires. miight try posting at www.oldgmctrucks.com as well get information flowing from other sources too. welcome to stovebolt.com | | | | | Joined: Feb 2000 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 69 | Take a look on the driver's side front frame horn, the serial number will start with K, then the model (31, 41, 71 101). | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Steve,
Welcome to the Stovebolt. I have no clue what year your new treasure might be, but the truck sure is interesting looking.
With all the winches and weird wrap around platform, it almost looks like it could have been some sort of well drilling rig.
Could long sections of drill pipe have been stacked on each side of the cab? If the truck is indigenous to the Sacramento valley area, maybe it was used to drill wells for the farms.
Stuart | | | | | Joined: Aug 2001 Posts: 3,613 Moderator | | Moderator Joined: Aug 2001 Posts: 3,613 | Cool truck What are those round dome shaped things in front of the rediator?
2-Ton 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Apr 2008 Posts: 8 New Guy | | New Guy Joined: Apr 2008 Posts: 8 | thanks for all the replys and links. i looked on the frame and havent found a number yet but im still looking. this thing shure is heavy, it broke a few boards on my trailer. [IMG] http://i31.tinypic.com/mbochh.jpg[/IMG] | | | | | Joined: Apr 2008 Posts: 8 New Guy | | New Guy Joined: Apr 2008 Posts: 8 | they say air spring on them [IMG] http://i31.tinypic.com/2m4zy92.jpg[/IMG]
| | | | | Joined: Sep 2007 Posts: 75 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 75 | Definitely something to do with the suspension. Maybe some type of shock absorber? | | | | | Joined: Feb 2000 Posts: 69 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 69 | Those are Gruss air springs, used as an accessory on many old trucks and busses. They are not shock-absorbers but actual air springs. Fill the bottom (one of two plugs, either one)with oil and pump them up with air (under the caps on top); they might still work. | | | | | Joined: Apr 2008 Posts: 8 New Guy | | New Guy Joined: Apr 2008 Posts: 8 | well you are not going to believe this. i was cleaning off the back bed and found the original data plate between two pieces of metal. its a K71B made in 1923. i did a google search and found this was the first year they started making this style and only 55 where built http://clubs.hemmings.com/clubsites/chevytalk/canadiangmc.html | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that's GMC's produced in Canada Steve, does the plate say "General Motors Truck Co of Canada Limited"? probably many more made in the US
Bill | | | | | Joined: Apr 2008 Posts: 8 New Guy | | New Guy Joined: Apr 2008 Posts: 8 | your right i dont think it was made in canada. the only info i can read on the data plate is the model number K71B and the serial number K712076 . i used the year from the link i posted. the link said the engine was a NORTHWAY MODEL 88 but the engine in it has the big gmc lettering like on the front.
| | | | | Joined: Apr 2008 Posts: 8 New Guy | | New Guy Joined: Apr 2008 Posts: 8 | | | |
