5 members (Hotrod Lincoln, Hanks custodian, Gdads51, Gray_Ghost, Maybellene), 80 guests, and 3 robots.
Topics128,066
Posts1,055,871
Members48,428
#405348 04/22/2008 2:44 PM
I have found a really nice '38 1.5 ton truck with a good windshield and other bits as well. What I'm wondering is if this cab and cab parts are close enough to the same to fit my '36. I know that the front clip is quite different but if the cab fits I might buy it for that and part out the rest. Any advice would be appreciated.
as for the windshield I don't think so but I'm not the expert here. I do know that on the Pickups the early 36 was a "high roof" and then late 36 came out with a low roof. Hang tight someone will chime in here soon.
I might add that on the pickups(you have a BIG bolt) that the cabs had wood in them. Then beginning in 37 the cabs were all steel.
Apprentice
Apprentice
The 36 low cab is different than the 38 cab in the windshield upper hinge, frame & glass height as well as wood front door body posts and wood floor boards. Chevrolet by 1940 used the 38 cab as a replacement cab for the 34-36 trucks. You do have to use all the 37-38 cab parts. I think the doors are the same.
34-35 trucks are the greatest
Well maybe I should just buy the '38 "just because". Of course then I might find myself spending more time in the shop and less time with my honey. I'm really trying to figure the down side there.
Apprentice
Apprentice
Shop around 36 low cab trucks are not that hard to find. All the 36 low cabs from the 1/2 ton to Maple Leaf 2 tons are all the same. GMC cabs for the same year are also the same.
