2 members (JW51, WICruiser),
300
7
Mod | | | Forums66 Topics128,078 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 99 | I have found a really nice '38 1.5 ton truck with a good windshield and other bits as well. What I'm wondering is if this cab and cab parts are close enough to the same to fit my '36. I know that the front clip is quite different but if the cab fits I might buy it for that and part out the rest. Any advice would be appreciated. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | as for the windshield I don't think so but I'm not the expert here. I do know that on the Pickups the early 36 was a "high roof" and then late 36 came out with a low roof. Hang tight someone will chime in here soon. I might add that on the pickups(you have a BIG bolt) that the cabs had wood in them. Then beginning in 37 the cabs were all steel. | | | | | Joined: Mar 2005 Posts: 11 Apprentice | | Apprentice Joined: Mar 2005 Posts: 11 | The 36 low cab is different than the 38 cab in the windshield upper hinge, frame & glass height as well as wood front door body posts and wood floor boards. Chevrolet by 1940 used the 38 cab as a replacement cab for the 34-36 trucks. You do have to use all the 37-38 cab parts. I think the doors are the same.
34-35 trucks are the greatest
| | | | | Joined: Sep 2005 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 99 | Well maybe I should just buy the '38 "just because". Of course then I might find myself spending more time in the shop and less time with my honey. I'm really trying to figure the down side there. | | | | | Joined: Mar 2005 Posts: 11 Apprentice | | Apprentice Joined: Mar 2005 Posts: 11 | Shop around 36 low cab trucks are not that hard to find. All the 36 low cabs from the 1/2 ton to Maple Leaf 2 tons are all the same. GMC cabs for the same year are also the same.
