0 members (), 136 guests, and 3 robots.
Topics128,110
Posts1,056,241
Members48,437
#4052 07/31/2002 3:44 AM
Fox
Offline
Putting a Must.II frontend in my AD truck. The company said the drop spindles would be too low. Not sure since I haven't got the kit yet. Anybodyhave pictures to compare the drop and regular spindles? How high off the ground do the drop spindles put the frontend? Thanks lots.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
FoxJ, have a look at this picture from my 38 I think the frames and heights will be similar. These are stock spindles and at the end of the frame the height is about 12-13 inches. That's without the motor or full radiator etc.etc. Adding all the running gear, fluids and sheet metal will bring it down to approx. 9-10. If you used the extra 2 inch drop spindles, your truck will probably be hitting every bump in the road.
http://community.webshots.com/photo/26859003/41133100InrrlQ
John....38 Chevrolet Panel Delivery
http://community.webshots.com/user/tobytailford
1 Offline
the mustang suspension as it came on the mustang will drop your ride height considerably to start with.....look at the photo of the truck with the S-10 front supension....building in the additional 2" drop will mean you will be scraping things going in and out of parking lots etc....we do not want to scrap off what we spent all that money to put on....*smile*
