1 members (Otto Skorzeny),
115
0
Mod | | | Forums66 Topics128,049 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Im coming down the homestretch on hittin the road in my Bolt, I need to Fab up or find something that would make a good under bed spare tire carrier, for a 15" wheel and tire. Ant Help will be Appreciated. Thanks Tim
| | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | What about something like the factory under bed carrier? | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Drew, Can one be purchased aftermarket or maybe hit e-bay ?..I know I wont find anything local.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | You can check this link but you won't like the price ($300+) Look at the picture they show and perhaps you can fab your own, save a buck or 300.
http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000014a~Z5Z5Z5AAFBZ~P319.50~~~~S2CO0QW0BP20930881350a~Z5Z5Z5~Z5Z5Z50000014x
~Jim
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Tips.....hummm....unless you're after the exact "original" equipment I's suggest you look into the spare tire mechanism found on a great number of 80's Chevy pickup trucks. It's a simple little ratchet winch mechanism with a cable that allows you to drop the spare to the ground and raise it effortlessly using a little jack handle. Much easier on the body than trying to muscle a spare up and get the bolt mechanism tightened.
Would imagine your friendly "vehicle reclaimation center" would be a great place to look...might even get them to roll an ole pickup on it's side to make unbolting it a bit easier.
Dave | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I would suggest you keep an eye on Ebay. It took a while, but I eventually got the whole setup. That is the carrier,j hook, hinge piece, lock bolt with wing nut, and even the the bed cross piece. I think I paid 125 bucks with shipping. In something like three hours I had it all down to bare metal and painted. Just be patient. It seems that things go in cycles on Ebay. Also don't just jump on the first one you see, if it isn't all there or damaged. By all means look everywhere you can think of. Also carry a list of the things you want. You never know where you will find somethig you need. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I have one of those on my truck, too. We fabbed up a separate crossmemeber for it and I used a McGuard lock for the cranking rod, with a 1/2' ratchet and 5/8" socket to drive it.
Bill Burmeister | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Find a Chevy LUV and grab the spare carrier from it. The easiest thing in the world to mount, works like a charm, and I bet you wouldn't have $20 in it. By the way...did I say how easy it is to mount? Four bolts, and you're home free. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I think it would be easier to find an original spare carrier up here than to find a LUV! Don't forget under bed carriers were not the same for all years of AD trucks. Some came straight down others were slanted to the right. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Thanks for teh repiles gents! I think Ill hit the local salvage yard and see what kinda deal I can get from newer truck with teh cable mechanism ...will post what I end up with. AGAIN THANKS! Tim | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Wise decision Tim; after all even if it doesn't work you haven't sent much money and you get the enjoyment of grazing the wrecking yard.
~Jim
