1 members (Phak1), 48 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#40383 08/04/2004 9:52 PM
Hello Chevy Dudes,got a problem for ya,,i was flushing out a 235 i have on my 50,,let truck run a while,,so it gets hot,,fluid coming out of overflow tube,,What the heck,,so then i see if theres any thing left,now i have a little steam coming out of radiator(cap part),,so i add water(she went down),,,what gives???,,I used Coca-cola for a flush,,I dont think that would cause the problem,,Any advice????? eek :confused:
#40384 08/04/2004 11:54 PM
Were you really serious about the coke? The sugar may cause you problems. You should really only use real radiator flush chemicals.
There is a normal amount of pukage out the radiator when you fill it freshly, since it will eventually seek its own level, just make sure it doesn't drop below the level of the core tubes in the top tank.
Paint & Body Shop moderator
#40385 08/05/2004 2:40 AM
I've used SOS dishwasher detergent before, but never Coke.
Mike from Alabama
My truck on Stovebolt
My website
Why do we drive on a parkway, and park on a driveway?
#40386 08/05/2004 2:55 AM
Somebody please tell me he's joking!
#40387 08/05/2004 4:06 AM
Your truck is showing glucose intolerance and maybe diabetic..... you should have tried diet Coke......
.....Like Jerry said....is he joking????
Bob C.........L.O.L.
Bob C.
CMP Heaven
The Hammond Barn
#40388 08/05/2004 4:07 AM
That almost makes me want to vomit!
#40389 08/05/2004 4:13 AM
Heck, I bet it is no worse than water. Just make sure you flush real good. And add some lemon.
54 3100 with 235
62 flatbed dump C60 with 261
#40390 08/05/2004 4:22 AM
I prefer Tab. It's cheaper than Coke and comes in a pretty pink can.
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#40391 08/05/2004 4:30 AM
heard of unseizing engines w. coke...but never flushing a radiator...still..ya gotta admire that sorta ingenuity! or..over-all common sense blockage..
1969 K20 , with a '67 front clip. fleetside. 292, 3x1 offy, headers. sm465 4spd. getting put back together, almost ready for paint.
doing it all myself.
19 and lovin' it.
"proper" is so over-rated.
.later days.
.sam.
#40392 08/05/2004 2:28 PM
Solowookie, where art thou?
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#40393 08/05/2004 6:37 PM
Quote
You got that right.
Need to add a little rum to that coke.
All joking aside, did you flush the system good after adding the coke? If not, you need to. A 50-50 mix of antifreeze, and only fill to one inch below the top of the radiator, leaves room for expansion so you don't lose as much coolant out the overflow. Only check the coolant level with the engine cold. IF you are still loosing a lot of coolant after that, you have problems to solve.
Fred
52 3600
69 C-10
#40394 08/05/2004 7:01 PM
Actually coke is quite corrosive. I use it around the house for various things besides drinking. grin Jess
1951 3100
#40395 08/05/2004 8:55 PM
The title of this thread reminds me of that pennzoil/quaker state commercial where an engine jumps out of a guy's vehicle after being fed bargain basement oil, and then the engine proceeds to puke black gunky oil all over the guy.
#40396 08/07/2004 7:17 AM
Well i hope the engine doesnt vomit all over me,,when the fluid level was down,i did put some water in it,so now its diluted,,I wouldve used real Flush stuff,but i cant see cotaminating ground and water below(maybe well water too,thats why i used coke,id rather repair or replace engine than wreck ground water( my opinion).. grin
#40397 08/07/2004 8:33 PM
Ha Ha Ha!!!!!!!
He can't use diet coke because real coke helps keep the fenders fat! grin
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
#40398 08/07/2004 10:19 PM
I could see it. Maybe heat some hotdogs on the manifold while flushing the engine.
When you flush your engine you need to catch the flushing liquid and all coolant and give it to the recycler that you also use to dispose of your used oil. There is no need to let it run free on the ground until it is very flushed and runs clear.
54 3100 with 235
#40399 08/08/2004 4:41 AM
you know what guys,next time i;ll think i'll use Pepsi,,Wait too many "CARBS",,,Ha Ha grin grin grin grin grin
