2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#399589 04/08/2008 4:49 PM
I am looking at Penrite Steering Box gear oil for my truck. I know some of you have used the John Deere oil, but Penrite is what I think I want to use. Is 1500 weight the correct one to be sure of no leakage?
Joe headscratch
Joe,
It appears that Penrite makes only one Steering Box Lubricant so you can't make the wrong choice.
This item is merely a NLGI grade 00 (double ought) grease. Castrol and many others make this item. It comes in a 14 1/2oz cartridge. It is self leveling, or semi-flowable, and will not leak out.
I looked at the old Chevron Dura-lith grease in '00' and noticed it had a much higher Timken load rating than the Penrite lube.
I would recommend to get what is easiest to get...all will work!
Stuart
Looks like some good stuff,might try it myself if what I put in leaks out,I just used 140w gear oil.
I like the NLGI rating also.
Corn Head Grease JD# AN102562 / NLGI O
Golf & Turf Cutting Unit JD# TY25083 / NLGI O
JDN-305 / JDN-360 / IH B-27 (Their is IH)/ NLGI OO
http://tds.econocophillips.com/catalogs/76%20Lubricants/Grease/FOB%20Cotton%20Picker%20TDS.pdf
Thank you everyone for your responses.
Now I got to get the grease out of the steering box to put the Penrite Oil in the box. Anybody got a quick way to maybe wash the grease out, or at least wash out what I am not able to dig out?
Thanx,
Joe headscratch
I used a pressure washer on mine.
Bluedawg
Bluedawg
God fearing, Gun toting, Constitution loving extremist.
I was recomended, and use a 50/50 of grease and gear lube.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
someone out here at one point said they used STP motor oil treatment. very thick and does not leak. Don;t know from experience, only repeating what I heard.
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
I use Alemite Hi-Temp #2, part # 9025-01, which is a hi viscosity fluid lubricant, with exellent results. Works well in the U-joints, too.
Bill Burmeister
lot of people said before '90 leaks'. I put 90 in mine, no leaks, and it steers great!
I LOVE MY TRUCK
1959 Chevrolet Apache 38 Panel Truck in the Gallery
Speaking of the gear box, what da hect are you spose to do with that little al. dothingy thats screwed into the gear box on top that has a little rod sticking out of it.
If I remember right in the manual it says to give this a pump now and then.
What I'm trying to figure out is how something is supposed to stay in that thing to pump if that be the case.
Or is this just some dodad that you can throw away and screw in a plug. Anyone got an idea ?
Dan
Remember your freedom - US Veterans provided it.
101st Screaming Eagles
Got the bulk of the grease out of the steering box today. I didn't pressure wash it because it is still in the truck. I removed the bottom of the box and soaked it down with brake clean several times. I dug most ot the grease out. Of course, there is still some in the box as it is impossible to get it all out, but I feel like I got 90% of it. I think the Penrite will eventually take most of that grease into itself and it will become part of the Penrite oil. Is that good, logical thinking, or wishful thinking?
Joe headscratch
