0 members (), 83 guests, and 3 robots.
Topics128,081
Posts1,056,318
Members48,442
#400762 04/11/2008 3:12 AM
hey guys,
i was test driving my 57 chevy 3100 yesterday, and going about 50mph, and it was really windy ouside, and i guess the wind was really coming in under the hood through the grille and radiator, because the top of the hood was shaking about, almost seemed as if it would tear through. LOL.
the outer edges of the hood was fine, just the center section.
any of you guys have this happen to you ?
my hood does have the 2 cross bars going from front to back, diagoanlly.
probably just an old truck acting like one. LOL.
thanks..leonard,.
1957 Chevy 3100 1/2-Ton
Photobucket pictures
Mine dances around pretty good, too. I do know that the adjustment of the latch can be touchy, took me several tries to get it right to keep it from bouncing at the front.
Bill Burmeister
thanks longbox55. my latch is adjusted fine, no worrys there, but the middle sheet metal really dabces around at speed and with wind..thanks..leonard
Is there some of of felt tar strips between the hood and diagonal cross bar supports? That's what my 63 and 68 trucks have.
Larry
I don't own a vehicle that isn't old enough to drink.
LGRIFFIN, i will check tomorrow, but i dont think so. i think the cross bars are about 1-2 inches away fromt he hood...thanks..
leonard
the TF trucks have nothing between the X bars and the skin, they're meant to keep the hood "square" .... the sheet metal skin on the 55-57's does wow a lot at speed, especially if there's also gusty winds - nothing to be done about it, the shape change in 58 eliminated the behavior
wow. thanks red... somehting i dont have to worry about. LOL.
thanks...leonard
Mine bounces around pretty good the second I get over 60. Its missing some of that felt stuff.
One of these days I will get around to fixing that.
SUPPORT OUR TROOPS
"Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan
1966 Fleetside SWB Webshots
Make sure your tires are well balanced. It will make a difference if the front tires are out of whack a bit.
