10 members (Bill Hanlon, pdlightning, 1955 1 Series, dt235sd, mo2cyl, FAST55, Steelonsteel, MikeE, sron48, klhansen), 75 guests, and 3 robots.
Topics128,050
Posts1,055,667
#400320 04/10/2008 3:02 AM
Hey everyone,
I just recently acquired a Chevrolet engine head that I do not need, and I would like to resell it - but I have no idea what it is!! It's actually the entire top of the motor with the intake and exhaust manifolds, thermostat housings, etc.
I was told is was a 230 head, but the intake exhaust manifolds are separate, like they are on a 235, and I thought that 230/250s had intake/exhaust manifolds that were attached.
So, anyway, I wrote down all of these numbers, hoping maybe someone here would be kind enough to tell me what it is!!
Here are some numbers from the passenger side of the motor, towards the front: 46F 2088
Towards the back of the motor, also on the passenger side: 2084
On the intake manifold: 3823418, GM 28, F121
And finally, under the valve cover:
towards the front of the motor: GM 18
in the middle: 084
Towards the back: 9962084
Thanks a lot!!
Any ideas on what this motor might be, or how I can find out?
Try Googling the casting numbers. I did that with what I thought was a Chevy engine - turned out to be an Olds engine.
Search for "casting number 1234567", or whatever WITH the quotation marks.
Hope this helps.
Thanks, where do I find the casting numbers on the head? I have read to find casting numbers on the block, but never the head.
Originally Posted by RobbieWright
......but never the head.
Me either. I took pics and posted them, and a lot of guys here were kind enough to help me ID what I had. I used photobucket.
1973-74 GMC & Chevy 250
catalog lists head casting # 3962084
No listing with a 9 962084
-Tom
1950 Chevy 3100 w/ 1956 235
Right! That was misprint from me, as I just checked the head again and those numbers match exactly.
But one thing that I am confused about, is the exhaust and intake manifolds are divided like on a 235, I thought that 250 intake manifolds were one piece?
Not all 250's had the integrated heads, just the later ones,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
The integral-intake head makes a pretty good boat anchor- - - -you've got the better one if the intake unbolts. The exhaust was separate on all the I-6's.
