9 members (baldeagle, TexasJim50, ndkid275, Gone, RaNfLaS, JW51, Shaffer's1950, Donf, 1 invisible),
41
Mod | | | Forums66 Topics128,005 Posts1,055,253 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 14 | sure need some advice. I got my truck home today. it is a 41 1/2 ton.it has a carburated 2.8 & 4 spd from an early s10 in it that is pretty much shot. I also have a rebuilt 2.8 in a 92 s10 that has fuel injection.What I need to know is if the early intake will bolt on to the late motor.or do I need to look for a good early motor.I dont want to rewire the trunk for fuel injection yet. thanks in advance for any help. Ron | | | | | Joined: Jan 2007 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 44 | I don't have first hand knowledge on this. When I was looking at options for the 2.8 in my Jeep I did a bunch of research.
You should be able to bolt the intake manifold up, and use the distributor out of your older engine. This is if your older engine has a vacuum advance. I don't think you will find one hanging off the '92 S-10 distributor.
Use care around the carb if you have the electronic E2SE on there. They're a pain in the backside. If you have the vacuum advance distributor, you should have a 2SE carb. That's easier to deal with.
There are some differences in the heads, but I think that has to do with valves.
If you are going to go with the fuel injection anyway, it may be worth your while to just take the plunge. Some of the brackets changed going from the early engines toward your '92, as did the mounting locations for them. I'm not sure on your engines. On the later engines, there is machine work that has to be done, as few of them had manual transmissions.
The swap that is most frequent is to the 3.4L Chevy from around '95. Chevy's crate engines can be retrofit to the early applications, but aren't ready for a clutch. They are assuming an automatic transmission. Time for some machine work.
This engine was used in the XJ Jeeps. I retrofit a 2SE carb and vacuum advance distributor from an early S-10 after the E2SE went south on my Cherokee.
There are upper manifold parts available for the aftermarket lower intake that allow conversion to Weber DGV or with a different part, Holley 390 4 bbl. That coupled with the later RV cam will get a bit more out of the engine. But! The best bang for your buck will still be a 3.4L conversion. It must be the Pushrod version of this engine. After they went to OHC and DOHC versions, all bets are off.
Good luck, and get more and better information!
Given the opportunity to start over, I'd just drop a 2bbl SBC in the Jeep. More power, same basic fuel economy, and much better parts availability! Hmmmm. Maybe in a couple of months.
CJ | | | | | Joined: Mar 2008 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 14 | thanks for the info. I am gonna pull the s10 motor tomorrow and get it ready to go in the 41. with any luck, I will hopefully be driving it next weekend..Thanks Ron | | | | | Joined: Mar 2008 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 14 | It worked!!! got the motor installed changed from a 4spd to a 5 speed. had to change the intake.Make a tranny mount and redo the clutch linkage.Waiting for a couple of friends to show up to help install the front clip. With any luck, I'll take it to the local show and shine tonite... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Congratulations peddlr!
Ain't ya got no pictures?
~Jim
| | | | | Joined: Mar 2008 Posts: 14 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 14 | yepper I'll post some as soon as I figure out how.I am a little slow at this puter stuff.But I am learnin...By jolly, I think it worked...hooray http://s175.photobucket.com/albums/w123/peddlr/
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I like that "wakeup" yellow, won't need coffee in the AM.
~Jim
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I like the Color!, Sharp lookin Truck! | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 |
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | |
