Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (farmallb, TGP, 1955 1 Series, baldeagle, Dennys28, cmayna), 67 guests, and 3 robots.
Topics128,004
Posts1,055,265
Members48,418
#391810 03/23/2008 2:40 AM
Anyone have anything positive to say about the latest
craze of inflating your tires with nitrogen at about $10 a pop?
gazim #391834 03/23/2008 3:14 AM
I use 78% Nitrogen in my tires. It works GREAT!
Bluedawg cool
O.K. I can't stand the waiting. Here's the punchline: AIR = 78% Nitrogen + 21% Oxygen + 1% Argon.
Save your money.
Bluedawg
God fearing, Gun toting, Constitution loving extremist.
gazim #391835 03/23/2008 3:14 AM
nope .... just check tire pressure regularly and save the coin ... unless you're talkin about airplanes or race cars
Flxible #391927 03/23/2008 6:39 AM
Apparently nitrogen does not leak out as fast as plain air.
Since air is motly nitrogen, you would have to assume all the oxygen and argon are what leaks, so if you keep refilling with air, the portion that is nitrogen will increase and eventually you'll almost pure nitrogen anyway.
I would not waste my money on straight nitrogen in an old truck.
OldSub #391954 03/23/2008 7:37 AM
Lol,
When I was a Crew Chief in USAF we used just 100% nitrogen in the jet tires & landing gear struts mainly because the 100% nitrogen will not expand and contract as wildly as air,we would service the struts(with air) and if ya had a cold snap over night the struts would LET DOWN to below the Go/No Go gauge, and require a fill up before flight, the nitrogen kept this under control.
In any desert environment it not uncomon to see a temp swing of 110 durin the day and then drop to the mid 50's at night, all the nitrogen did was make out lives a bit easier than havin to service a bunch of struts in the mornin before flights started.
I really dont think it is a critical part of a vehicles life....lol
Just my 2 pennies.
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #391998 03/23/2008 3:01 PM
Thank you, you just varified my assumption.
gazim #392623 03/24/2008 9:30 PM
Apprentice
Apprentice
the craze to nitrogen is simpley becouse regular compresed air contains water vapor and on an alluminium rim the moisture causes the rim to oxidize creating leaks or a bad seal, 100%nitrogen eliminates this problem. If you fill your tires with nitrogen once you have to maintain it with pure nitrogen otherwise you will contaminate and have to start all over. It can be costley but if you are sick of trying to figure out why your mag rims constantly leak it is a good solution.
it's not how much time you spend on it, it's how you spend your time with it
burbnburp #392628 03/24/2008 9:48 PM
"MONGO"
"MONGO"
When you buy tires from Costco around here they do nitrogen in them. It's included in their regular mount/balance charges.
I've had it in a couple different sets they've done, didn't realize any difference really other than the little green Caps they put on them.
MONGO
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
KCMongo #392714 03/25/2008 1:03 AM
Or just check your tires regularly and fill them up as needed.
Hot Rod Dad #393099 03/25/2008 9:45 PM
If they pressure up your tires with nitrogen to 30 PSI, the tiers will still have about 7% oxygen in them. Only practical way to get out all the oxygen is to do several cycles of pressure up, then bleed off the pressure. I doubt they will take the time to do that.
Harold Wilson
41 Chevy 3/4 Ton
Harold41 #396032 04/01/2008 12:17 AM
i'm still lookin' for factory air for my old bikes and vehicles.
actually i get free nitrogen at work.
as SW & burbnburp says .........
Jim & Caroline
