| | | Forums66 Topics128,052 Posts1,055,771 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | I searched for this and found a few old links but they didn't answer my question real well. I just got down creating myself a parts washer using some heater hoses a small pond pump and 1950 era washer. I went to fleet farm and got the parts washer fluid they had there. I was a water based green cleaner. I have used it alittle and it works not incredible well scrubbing is required but it does loosen the dirt. My question is this what type of fluid do you use for your parts washers and where does one get it. I know some people used gasoline and I do to but I am not running it through my parts washer. The pond pump is supposed to be used in "fresh water" only. For 12 bucks I am giving it and possibly the fire extingusher a little trial the thing is solid plastic so I am auctualy not that worried about it as long as gasoline isn't used it should be fine. Thanks for the advice. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I use Safety-Kleen solution. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm not sure what forum it was in but back a few months of ago there was some extensive post about this. I think the jest of it was that most cleaners are mineral spirits of some sorts. I don't know the brand but I get mine from my nephew who buys it in 55 gal drums. It ain't cheap but works pretty good. Seems like it was about a buck fifty a gal(??) Do a search on a couple forums and you'll probably find enough info to keep you reading well past midnight. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm not sure what forum it was in but back a few months of ago there was some extensive post about this. I think the jest of it was that most cleaners are mineral spirits of some sorts. I don't know the brand but I get mine from my nephew who buys it in 55 gal drums for his machine shop. It ain't cheap but works pretty good. Seems like it was about a buck fifty a gal(??) Do a search on a couple forums and you'll probably find enough info to keep you reading well past midnight.
| | | | | Joined: May 2005 Posts: 39 'Bolter | | 'Bolter Joined: May 2005 Posts: 39 | If you run gasoline through your pond pump you can almost garuntee a fire. I'll bet the pond pump is water tight / water proof, but I'll bet it's not explosion proof.
My next door neighborh used a small electric pond pump to try to siphon the gasoline out of his Toyota pick up truck, before he sold the truck. Guess what happened next. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | NEVER USE GASOLINE TO CLEAN PARTS !.....keroseen works great, but safety clean is better. a fuel pump from a vehicle works good with a ac to dc inverter on a home made parts washer...make sure you ahve a good size filter on the return line to the pump. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I use "parts cleaning solvent" (kerosene I think). There's two places in town that sell it. It doesn't touch dirt but eats anything oil based. It's pretty high dollar stuff too. I'm not sure if you should run it through your home made setup though. It'd probably eat your pump up.
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I have always used kerosene with good results. | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Another vote for kerosene here!  | | |
