1 members (Hotrod Lincoln),
116
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | guys can you simply add a lock asssembly to a 50' chevy drivers door by cutting hole in door and retaining lock with proper clip? it has the pull down handles and i have done it to 51' up doors by adding lock to handle assembly. thanks. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 10micron: I would say "yes" and I also just saw the lock assembly and the retaining clip in a JimCarter catalog. | | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | The latch assembly has to have a lock mechanism built into it. The pass side has it,to where it can be locked from the outside,, I dont think the driver side has it. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No the latch up to '51 did not have provisions for a lock, I have four in front of me and the left side is missing the keystone punched lock paul. Denny Graham Sanwich, IL
Denny G Sandwich, IL
