| | | Forums66 Topics128,005 Posts1,055,261 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Hey guys I have looked thru all of the vaccum wiper topics and could not find out a way to bench test my wiper motor other than using a vaccum cleaner and funnel the hose down to the size of 1/4 vaccum line...is that the only way? All help would be appreciated! Thanx, bowtie | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | You can also use a suction type, hand operated, break bleader. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well this probably won't help ya but I have a Sargent-Welsh vacuum pump that I got from a guy that did AC servicing. It will take a system down to ten to the minus third atmospheres. I’ve used it to check a few Trico vacuum motors and if they won’t work with that pump, they won’t work. Vacuum is pretty tricky, you really need a tightly sealed system for it to do it’s job. A vacuum cleaner pumps a lot of volume but not a very high vacuum. What you need is hi-vac and low volume. Your engine or any engine is most likely the best vacuum pump available to the average Joe. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Just hook it up to a running car/truck engine. Find a vacuum source and plug it in. It will simulate real operating vacuum instead of guessing at it with non-automotive equipment, Scott | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Thanx guys, Ill give 48bigtrucks a try. | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | Just hook it up to a running car/truck engine. Find a vacuum source and plug it in. It will simulate real operating vacuum instead of guessing at it with non-automotive equipment, Scott That's the ticket.  Now then, please remove the criminal in your avatar before I call the feds... | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | That's the ticket.  Now then, please remove the criminal in your avatar before I call the feds... I don't know where that ugly cuss came from but it's sure good for a laugh, ain't it? LOL Scott | | |
