Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (MickeyP, baldeagle, Gdads51, Hotrod Lincoln, klhansen, KingG), 56 guests, and 0 robots.
Topics128,007
Posts1,055,281
Members48,418
#388686 03/16/2008 1:53 PM
Hey guys I have looked thru all of the vaccum wiper topics and could not find out a way to bench test my wiper motor other than using a vaccum cleaner and funnel the hose down to the size of 1/4 vaccum line...is that the only way?
All help would be appreciated!
Thanx,
bowtie
bowtiesr4me #388693 03/16/2008 2:37 PM
2 Offline
You can also use a suction type, hand operated, break bleader.
bowtiesr4me #388696 03/16/2008 2:44 PM
Well this probably won't help ya but I have a Sargent-Welsh vacuum pump that I got from a guy that did AC servicing. It will take a system down to ten to the minus third atmospheres. I’ve used it to check a few Trico vacuum motors and if they won’t work with that pump, they won’t work.
Vacuum is pretty tricky, you really need a tightly sealed system for it to do it’s job. A vacuum cleaner pumps a lot of volume but not a very high vacuum. What you need is hi-vac and low volume.
Your engine or any engine is most likely the best vacuum pump available to the average Joe.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny Graham #388710 03/16/2008 3:27 PM
Just hook it up to a running car/truck engine. Find a vacuum source and plug it in. It will simulate real operating vacuum instead of guessing at it with non-automotive equipment,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
48bigtrucks #388874 03/16/2008 9:18 PM
Thanx guys,
Ill give 48bigtrucks a try.
48bigtrucks #388902 03/16/2008 10:46 PM
Scott
That's the ticket. thumbs_up
Now then, please remove the criminal in your avatar before I call the feds...
Avette4me #388994 03/17/2008 1:33 AM
I don't know where that ugly cuss came from but it's sure good for a laugh, ain't it?
LOL Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
